    Results 1 to 20 of 25
      Jan 2002
      Italy
      PCV inside a AN hose or fitting?
      Hi,
      from my one valvecover to the intake manifold I'll run a PCV valve but I'd like to hide it inside an AN hose or fitting to avoid using the ugly rubber grommet, have any of you tried this??
      are there different sized PCV valves around?
      thanks!
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      Oct 2005
      Granger,IN
      Use a crankvent, its a fancy bilet aluminum PCV valve.
      They have a AN connection version but its not shown on thier webpage
      http://www.et-performance.com/turbo.html
      Free hostings of solid models!
      http://www.wrenchmonkey.com/Webpages/Solids/Solids.html
      92 Stealth Twin Turbo with 3.5L Engine swap
      Looking for my next project, maybe an AWD 71 Lemans????
      Jan 2002
      Italy
      thanks, looks like what I need, but at a whoppin $110!!!!!
      I might end up getting it if I cant find anything cheaper but other ideas are welcome.
      Have Fun!
      André
      Oct 2005
      Granger,IN
      EDIT: A PVC valve is NOT the same as a check valve, soory for the bad idea:(
      Isn't a PCV valve just a ball check valve? search mcmaster Carr
      http://www.mcmaster.com/
      Jan 2002
      Italy
      thanks, I'll look into that
      Have Fun!
      André
      Oct 2005
      Granger,IN
      Quote Originally Posted by Tigergutt
      The crankvent sellers claim that the crack pressure and opening speed is critical, I have no clue
      Jan 2002
      Italy
      wow, that I dont know..... but a ball valve should be pretty fast as well...
      but I know that without any valve in case of an engine backfire it might ingnite the crankcase gases and blow the thing apart.....
      Have Fun!
      André
      Jan 2002
      Italy
      Ordrered a 3/8"npt stainless ball check valve from Mcmaster today, thanks for helpin!
      Have Fun!
      André
      Chesapeake, VA
      I don't think you want to do that. Please see here: http://www.jalopyjournal.com/forum/s...ad.php?t=61376 it explains the PCV system thoroughly complete with a cutaway PCV valve and an explanation of how it works.
      Jan 2002
      Italy
      Thanks for replying, I read the article (very nice) and didnt find the reason to not use a ball check valve.
      is is due to the different flowing rate of the pcv at different vacum?
      thanks!
      Have Fun!
      André
      Chesapeake, VA
      Yes. I believe your engine will see a massive vacuum leak at idle. The PCV actually flows LESS under high vacuum (idle) and MORE under low vacuum (wot or heavy load) because the shuttle inside the valve is pulled farther into the orifice with increasing vacuum.
      Jan 2002
      Italy
      considering that you are probably right.
      Since I already have it I'll give it a try anyway and see if it causes a major vacum leak.
      Have Fun!
      André
      Oct 2005
      Granger,IN
      Sorry about the bad information, thanks for the good link on PVC valves!
      I felt so bad for leading you astray that I went to the autoparts store and they let me look through thier selection of PVC valves.
      Purolator PV1020 looks like 2 barbed hose ends butted together. One end is made for a 1/2" diameter hose and the other end is made for a 3/8" diameter hose. The biggest part of the body is .594" in diameter.
      You might be able to slipit completely inside a #10 AN hose.
      If you turned it down on a lathe or even just filed it down in the center it would definitely fit completely inside a #8 AN hose
      Newbury Park, CA
      Take a look on my website at the engine picture. In the LH valve cover I use a modified AN "el" that has a GM PCV check ball setup installed. I purchased it from a local hot rod shop. I know where it is but I don't remember the name. If interested, I can stop by there next week and find out if they still carrry them.
      Jan 2002
      Italy
      thanks guys, I might eventually just buy the one from et performance.
      or a ground down pcv insice a hose...
      I'll ask my buddy in SF if he can drive by an auto parts store and get me a Purolator PV1020.
      thanks for helpin
      Have Fun!
      André
      Have you looked at Earl's breathers?
      Search on pn EAR-3434116ERL at www.summitracing.com
      jp
      ​John Parsons
      Jan 2002
      Italy
      yeah I have looked at it but I do not like it, ts not to be a picky ass but I dont want the grommet style....
      I do indeed really appreciate your suggestions here
      As for now the idea is to have one AN-10 weld bung in each valve cover, then stick the PCV inside the AN-10 hose that goes to the manifold (as John suggested), the other AN-10 would go to a Moroso breather tank on the firewall.
      Have Fun!
      André
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by CarlC
      Carl, that is clean.
      This is the best pic I see: http://www.geocities.com/casanoc/alt_1.JPG
      I've always liked those covers. Did you have any problems with the PCV setup and oil? I've had issues in the past with non-baffled covers - PCV draws oil mist in, and oil out the breather too. But I never tried taller ones like those.
      Scott from NJ.
      Vent Windows Forever! ...
      TuoCo, CA
      I'd be interested. That is a sweet setup!
      Steve
      Check it Out Here
      Chicago
      Quote Originally Posted by eville
      is there any reason that you couldn't mount it the verticle surface on the back of the valve cover.
      marty-mj
