    Thread: trans lines
      Aug 2006
      trans lines
      hello,has anyone used braided line for cooling lines? i hate rubber line and worm clamps, iv'e got a 70 chevelle th400 and a b&m super cooler custom mounted i front of my radiator thanks
      Metamora, Illinois
      Yes I am using -6AN braided lines for the transmission. I don't like the rubber hoses either, but the cost of braided lines and AN fittings add up in a hurry.
      northern california
      I Am Also Running Braided Lines Not One Leak.used Earls Trans Cooler.
      CT
      Same here...
      Homer Glen, IL
      Anyone run braided trans lines with DSE coil over front end where did you run the lines on the frame? Over under around upper control arm?
      Joe
      Concord, CA
      I'm running that new Earl's rubber flex-braid line. It's better than straight rubber and because it's black already, doesn't get dirty and dingy like steel braided lines get after awhile.
