    Results 1 to 10 of 10
      Picking a welder...tig..mig?
      If you had to choose the most flexible welder when it comes to restoring a car (sheetmetal repair, chassis fabrication, roll cages), what would it be? I've been checking out some of the TIGs out there because I eventually want to weld some aluminum too. Speed isn't as much of an issue as I have a lot more time than money (well, maybe a LITTLE more time).
      I'm just trying to avoid buying 2 welders. If im going to need two anyway - then I guess I'm looking for a good suggestion on a MIG?
      May 2006
      IMO the lincoln Precision TIG 185 is not a bad choice. it will give you the option of stick or tig and the consumables are easy to find. it will handle chassis fab to alum welding and has a decent price. about $1600 ish. welds great and willl penatrate 1/4 (tig) as well. more than enough for auto shop work.
      sorry i cant help on the mig i have a Millermatic 175 and am very pleased with it. i dont use it very much sicne i got the PT 185.
      either way get a 220v or greater. better Duty cycle and better performance (arc stability)than 120v units.
      Nov 2003
      Paradise, Ca
      MIG will do everything you want if you're talking about aluminum 1/8" and thicker. You'll need a spoolgun at minimum for that though. TIG only falls short on body work type stuff.
      Just face it, you'll end up with both eventually anyway.
      -Matt
      Woodbine, MD
      ok...I have a hobart handler 120 mig. nice lil welder. Im new at all this welding stuff so dont laugh...but what are the advantages to a tig over a mig? what can one do over the other??
      I have mig welded before (a monkey could mig weld)...and I took a class on stick welding (pretty much useless)...but i have no clue about tig. If I was to get a beginner one....what would you all suggest? I really want to get better at welding b/c I have some major ideas for my car....
      Nov 2003
      Paradise, Ca
      I can't find any of my posts before April of this year, but I know I've talked about your questions before. What you're asking can get pretty in depth and I'd rather find my old posts on it.
      Ralph?
      -Matt
      I've read quite a few scattered threads on other sites regarding this, and have formed SOME opinions on the matter. I wanted to ask here because I believe the percentage of people who actually do thier own work (here) is higher.
      Thanks for the replies do far. Guess I could just tell the wife that everyone says I need two welders
      The only negative thing I've heard about TIG is that it generates a lot of heat and can warp body panels...but so can MIG, right?
      Jeff
      Woodbine, MD
      oh yes. If you have a mig turned up to high...it can warp and even burn through panels very easilly......dont ask me how i know this.
      Buy a MIG to start. Get a real MIG welder with gas shielding. I'd recommend you buy one of the name brands, like Lincoln or Miller. Buy it from a local welding supply store (watch for sales), and establish a relationship with them; you'll need gas and consumables.
      Lincoln and Miller send reps out all the time and hold open houses at such places and you can try out welders and get some hand-on tips for usage and such. Later, when you're ready, (or when your wife has forgiven you for the first welder purchase) buy a TIG machine.
      jp
      ​John Parsons
      Woodbine, MD
      stupid question. I have a hobart 120...that has flux core wire in it. It had gas, but my dad changed it over. I still have the bottle...and the set up. What do I need to do to get it back to gas...and why would i want to use gas over the flux core?
      Sorry guys, I'll have to pay more attention. Matt has left (permanently, he says) so we'll all have to pick up the slack for these welder questions.
      Have a look here.
      jp
      ​John Parsons
