Results 1 to 20 of 20
08-20-2006 #1
Hal gmp15 coil overs In Second Gen Camaro
I was wondering if any has tried the Hal gmp15 coil overs & shocks for street use? Anyone tried using the Hal - tcp2109p for the rear shocks? on a 71 RS....Do you have to modify the stock arms?
I do have Eaton 5 leaf rear springs that i bought from D&R a few years ago..and have no road use...at that time no one offered lowered rear springs...like Hothchkis does now...i was just wondering what the stance would be like..anyone have pictures to post or send to me would be great...kind of looking for that pro-touring look...lowered look...its been a long process of replace the all front sheet metal and both rear quarters..rockers..tail panel and wheel houses..shaved door handles and seams..fiberglass rs nose...no bumper bolts on any of the front and rear bumpers..finishing up body work now.....motor and trans are out of car..subframe stripping next with with upgrades to front suspension....not going to road race...just going for the lower stance....also what would recommend as for bushing to use on subframe?
08-21-2006 #2can anyone help
08-21-2006 #3
Starting The Transformation
- Jun 2006
- Hiawassee,GA
- 134
Wish I could help, I've got the same plans,but am not as far along as you. The guy I bought my car from put air shocks out back, I guess instead of replacing sagging springs. Thought I might put lowering springs on and just air up the shocks if need be, till I have the $$$ to do the whole suspension. I will just be happy to put the car on the road at this point!
Jim
71 Camaro RS
73 Jav/AMX
www.musclerides.com www.nastyz28.com www.smokinchevy.com www.chevythunder.net www.clubhioctane.com www.camarosource.ca
08-22-2006 #4lowering
Most likely those Eaton springs will be kinda high. My 71 z28 sits with the top of the tires just inside the wheel well. I have a Rancho, yes Rancho spring, shock, and sway bar set up on my car, I also have the front spring mount re-drilled 1/2" lower, and 1/2" lowering blocks in the rear. Try Nastyz28.com, it is a 2ng gen site and really good too. I have pics of my car if you send me a PM I will send them to you. With the Eaton springs atleast a 1" lowering block is needed. I went my route because the more lowering block the more wheel hop, also the re-drilling of the front mount changes the roll center for the beter. anything to help a fellow 2nd gener
my 2cents
Keith
08-22-2006 #5Hey thanks for the information
I do belong to the second gen site...I did a post there too..no reply..that's why I thought I would try here...
I did call QA1 today about there front coil over conversion...the tech guy told me the most you can lower the kit is 1 1/2" with out running into problems...with shock travel and geometry problems...my front springs are shot...the other owner had those twist knuckles in the spring with rubber blocks...I also had / have the air shock problem in rear shocks from the other owner...didn't change yet because of stripping the underside.then painting..so in the front I think in front ill go for the QA1 coil overs instead off hotchkis 2" lower coils and koni adjustable about 150 difference in price...I'm going to use the eaton springs with 1 1/2" lower block...I can always take it to work and machine it down...that way I could tell more closely where the hotchkis 1 1/2" lower rear leafs would sit my car...I did see the herb adams modification on the second gen site about modify the front spring pocket...but I thought it would make it week...is yours ok so far.....did you plug weld the old hole shut?..I can also do that mod at work too...did it make a difference in cornering?...I think that im going to try the QA1 tc2109p for the rear shocks...instead of the konis that way all shocks same manufacturing....So how do you think this all sounds...sure send some pics of your car...I also ditched the 3 pc rear spoiler for a Toyota one...looks cool
08-26-2006 #6
- Jun 2006
- Hiawassee,GA
- 134
I'm kinda surprised no one @ NastyZ responded, I'm a member over there as well, never had that problem. How bout posting the pics here, so we can all check em out!!
Jim
71 Camaro RS
73 Jav/AMX
08-27-2006 #7torval
i guess you were asking about the rear spoiler pics?
these were taken after i replaced the rear completely...New rear quarters, rockers, rear tail panel inside and out,outer wheel houses..also shaved the door handles, side marker lights front and back... and most of the seams...thinking about doing the headlights to upper rs valance....i did do the upper rs valance already between parking lights RS ones...but i would like to get rid of the seams where the healight splits...i have to wait until i remove the subframe to do these seams...i dont have any pics on the new nose and roughed in body work...the bumpers waiting to get reblasted from welding and there was still some spots that had chrome on them...I going to get the body a little closer this week and try and remove the subframe next week..the spoiler fits better then this picture...i had to do a lot of work to deck lid...and the trunk isnt latched either
03-30-2008 #8
