      Jun 2005
      Pinetop, Az
      Which 2004r will live?
      This would be for a 3750lb 69 camaro running right at 11.5 (500rwhp). 50 dragstrip passes a year, 5000 street miles, maybe 10 30 minute sessions on the road course over a year.
      I'm looking for one that will not give up any performance of the current th350 with the gv setup, a lock up convertor for the street (3000 stall or so) and not get overly warm on the road course and LIVE.
      Ideas????? Thx!
      Aug 2006
      Cibolo, TX
      Metamora, Illinois
      Is there a compelling reason you want to switch from the TH350/GV combo?
      Jun 2005
      Pinetop, Az
      The th350 with the gv does work pretty darn well, but there are some reasons to make a switch.
      1. With a 2004r I could go back to my 3.73 gears (rather than the current 3.42's) and not only lower my 60fts with the better gearing and 1st gear trans ratio, but also drop the cruise rpm's several hundred rpm's on the top side. Street/strip ride.
      2. My 67 bbc camaro could use the gv unit on it with the th400 for the long straight on one of the tracks that has that car running out of gear 3/4 down the long straight. I like the idea of another 20 mph on the top end. Strip/street ride.
      I don't mind spending a little more $ to get a setup that works as good at the track as the current setup, works better on the street, and gives me as few as troubles also. Thx!
      Metamora, Illinois
      Here is a list of reputable 2004R builders from www.turbobuick.com You may want spend some time over there many of the top 2004R builders in the country post there regularly.
      http://www.turbobuick.com/forums/showthread.php?t=84598
      I have heard good things about PST Xtreme, Dynotech Transmissions, Janis and CK Performance. Personally I bought mine off a turbobuick member named Brian Hofer.
      I did some searching and it looks like there are a couple of built 2004Rs for sale now.
      http://www.turbobuick.com/forums/sho...ighlight=2004r
      mo
      checkout dynotech performance,they build some of the best 200r4s.i've seen 200r4's run 8's.i would swap them.
      Jun 2005
      Pinetop, Az
      I have emailed a couple of these guys. Thanks for the info! You're the rocket-man.
