    Results 1 to 20 of 27
      vancouver, BC
      ATS - AFX spindles / balljoints..
      Im looking at getting the AFX Spindles.. im just wondering which balljoints would work best? the stock height, or the 1/2 taller balljoints!
      And also.. are the adjustable control arms easily adjustable for the average wrencher?
      thanks
      kevin
      73' pontiac ventura.
      383 powered, stock chassis
      12.45@112
      Oct 2003
      Arvada, Co
      Just get the tall spindles and be done. What control arms are you referring to?
      Brian
      vancouver, BC
      the ones for sale on the ATS page..
      the SPC adjustable control arms..
      says they work with the AFX spindles nicely.. but i dont want to get something that is above my skill level!
      So are you saying get the stock balljoints only? I was already going to get the tall AFX spindle!
      kevin
      12.45@112
      Quote Originally Posted by baz67
      For a complete street car, that will never see an AX, road course, or probably a drag strip, how much more advantageous is the tall spindle over the tall ball joint? I'm getting ready to swap the drums for discs, and I'm trying to decide if the newer spindles are worth the extra effort required. (I know, it's not much extra effort, but if it's not warranted...)
      Mar 2002
      Redwood City, CA
      Use stock height ball joints with the tall AFX spindles. The good geometry is already designed in.
      Allen Ortega
      Use the SPC adj UCA's with the Howe, stock height ball joint.
      I had the SPC adjustables with the tall Howe bj, before I bought my AFX spindles. I called Marcus at SC&C and asked what he thought about using the AFX and the tall bj, and he advised agianst it. So I ended up buying the stock height studs when installing my AFX spindles.
      Stuart Seitz
      vancouver, BC
      perfect. thanks for the feedback guys
      12.45@112
      PA.
      I dunno how I missed this thread but Stuart has it right. The AFX spindles don`t need taller ball joints for great geometry. A lot of folks opt for our modular CNC ball joints simply because they`re much stronger,smoother and more precise than OE ball joints but stock ball joints will work okay also. Mark SC&C
      vancouver, BC
      yep, for the price it looks well worth it to upgrade to the better balljoints.. they just came in two flavours and i wanted to make sure i was getting the best i could
      12.45@112
      Sep 2001
      Accord, NY
      Quote Originally Posted by Marcus SC&C
      Mark, just to be clear (to me). Your comment is in regards to the tall AFX spindles?
      68 camaro - SOLD
      Mar 2002
      Redwood City, CA
      It's worth it. You can put any C5 Corvette brake kit on the AFX spindle. It opens you up to better brake setups. To me, that makes it worth it. The handling advantage is worth it on it's own.
      Allen Ortega
      Sep 2001
      Accord, NY
      My car is basically a street car. I went with the SC&C adj UCA's and tall ball joint. I love the AFX spindle. Maybe some day for ABS when the rumored setup is available.
      68 camaro - SOLD
      PA.
      Rick, yeah those comments were directed towards the tall spindles. BTW AFAIK they have a number of the std. height spindles in stock for those who already have the G mod and or tall ball joints. With both combined the geometry is almost identical to the tall spindles. We just released a new SD (Severe Duty) Xtra tall upper ball joint for 1st gens and A bodys too. It`ll be in our new Stage 1-Plus and Stage 2-Plus packages. Without doing the G mod the camber curves etc. are more aggressive than the G mod. Combined with it it`s even a bit more aggressive than the SC-AFX with the tall spindles. We`ve got the whole spectrum from mild to wild covered now and it`s all modular so we can tweak it to suit each individual car/driver perfectly. Mark SC&C
      PS. Polished nickel ball joints with red caps...soooo shiny...you know you want em!
      Nov 2004
      Germany
      Balljoints
      Hallo Marcus ,can you post a picture with the new SD xtra tall balljoint,can I update my stage two?( Chevelle 71 454SS) I`m really interested!
      SouthTX
      Not wanting to hijack but just add a little more depth into the discussion:
      Which Global West arm work best with the ATS A-body spindle?
      The negative roll series arms for b-spindle swaps or the oem type "Gplus" GW arm?
      Negative roll http://www.jegs.com/webapp/wcs/store...tegoryId=77723
      G-Plus
      http://www.jegs.com/webapp/wcs/store...tegoryId=73104
      La La Land, CA
      It must be used with the Negative Roll arm for a B body 'tall' spindle, the OEM arm will have ball joint bind like a stocker would.
      Tyler
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by TitoJones
      Tyler
      I'm running stock A-body spindles with Global West and ART StrongArm control arms on my 69. Are you saying I would have to buy different control arms to run the ATS spindles?
      Phoenix,AZ
      How dose wickedmotorhead g-body handles? I'm still try to decide on going with SC&C stage 2 kit or the Street-Comp AFX.
      PA.
      Clint,where there`s a will there`s a way. There have never been more great suspension options for A bodys. The Stage 2 package Tyler mentioned will give you similar suspension and steering geometry gains vs. the AFX setup. The AFX setup is more agressive but the Stage 2 still makes very impressive gains and a huge improvement in performance and drivability. You can probably Ebay your existing GW arms for almost as much as a complete Stg.2 with adj. tubular arms. You wouldn`t be the first to do that. ;) If you have any questions give me a call at the shop sometime.
      Tyler,the REALLY scary thing about FatMan and their spindle issues is that I pointed those things out to them 2 years ago at the SEMA H&R show when the spindles were still a plastic prototype! I didn`t have to tell them,they`re competition,but I thought I`d be a nice guy and save em some headaches. Sigh.... Mark SC&C
      Nov 2002
      Georgetown,TX
      Mark SC&C
      I'm beginning to think you may be right,Mark. Just tried to call you a few minutes ago but I guess you had already closed up shop for the weekend. Will try again soon.
