Results 1 to 9 of 9
Thread: Second gen Trans am LCA question
- Jul 2006
- Hackettstown, NJ
- 1,026
I did a search in this forum hoping to find an answer but found a bunch of dead ends. I am looking for a set of Tubular lower control arms. I understand that geometrey will remain the same which is good. I am running coil over's, so a little more strength wouldn't hurt. I have gw's UCA. other than stock or GW's , I can't find any that will be able to take stock diameter bushings (i am a fan of intercahangability should you need to replace something in a hurry). looking to fit Del a lum bushings into the LCA. I have look at the following companies and this is what I have found:
GW's - seem like the best choice, costly
BMR - seem just as good as GW but have their own size diameter bushings (no interchangeability)
Heidts - seem good, but when you have to add the cost of del a lums, you are better off going with the gw's
Stock - well , its stock, simply put. strength??
wondering if anybody has any input on this subject.
