Results 1 to 20 of 20
07-28-2006 #1
aftermarket accessory brackets - HELP!
I'm new to this forum and am looking for some expert help.
I have a 66 Chevelle SS with a 461BBC and T-56 trans. Detroit Speed worked a bunch on the car when their shop was still in MI (I was 10 minutes from them then , NC is a bit further).
I need some help with aftermarket accessory brackets.
Despite searching all the suppliers I could think of in the industry (March, Billet Specialties, Zoops, Alan Grove, DSE) I can't find a set of brackets that will work for all the components. The car has Vintage Air AC compressor mounted on passenger side (outside the head), Billet Specialties alternator on driver's side (also outside), short water pump, and power steering including the factory gearbox. The car has Billet Specialties brackets on it now for the AC and alt.
The main problem I have is finding a bracket setup that will work for the PS. I can go with a Type II / TC-style pump from Detroit Speed (preferred direction) or even a stock style pump (2nd choice), either with a remote reservoir. But no one seems to make a bracket that will allow the pump to clear the gearbox from below and to the side, and still clear the alternator bracket from above. If I change brackets to clear one, I run into the other and vice versa.
The alternator brackets all seem to utilize the lower bolt hole location on the head, which is where the pump or its bracket interferes. The PS belt has to run on the forward groove of the 3-groove crank pulley so the pump also has to clear the alternator belt routing; I can't run both the PS and alt on the same belt.
The car has a BeCool aluminum radiator and dual Spal fans, so a Front Runner or other serpentine system is out for me, no room without totally reworking the radiator brackets and fans. Plus I'd prefer not to have to go the swap meet route with the existing compressor, alternator, water pump, fans, brackets, etc.
Anyone out there been down this road and know which route to take? Suggestions very much appreciated.
