Thread: Running rich = Running hot?
07-25-2006 #1
- Aug 2004
- 345
Is it possible that running verry rich would also cause higher engine temps? my car is running hotter now that i have put it back together but it may be due to the tranny cooler in front of the radiator. but im also running verry rich and didnt know if there was possibly a connection?
07-25-2006 #2
- Aug 2004
- Clovis, Ca
- 109
A rich condition does not usually cause a motor to run hot that is usually attributed to a lean condition. You my have some other condition causing the motor to run hot.
But higher air temps will cause a rich condition.
Sound like you have two separate conditions, one causing the motor to run hot and with the heat of the summer causing the rich condition.
07-26-2006 #3
