Thread: TH350 leakage issue
07-24-2006 #1
New to Pro-Touring
- Aug 2004
- Flint, MI
- 59
TH350 leakage issue
I have a TH350 in my Nova that has been leaking for several months. I have a TCI high capacity pan (2 additional quarts) and for some reason I can not conquer this problem. I tried the felt gasket that came with the pan, cork, rubber and finally a silicone gasket and it won't stop. I think the next step is to take the pan someplace to see if it was properly machined but if any of you have some pointers it would be greatly appreciated as I am tired of changing gaskets.
07-30-2006 #2maybe the leak problem is not the pan . he can origin elsewhere and flow up to pan join . do you have removed the inspection cover ? the tork oil seal , pump o-ring and pump bolt can leak . the speedo gear housing , gouverner cover , modulator , yoke oil seal and vent tube can leak too . personnally I already haved probleme like your and the leak was , the pump bolt seal ! good luck !
07-30-2006 #3Along the lines with pontiac bird, make sure you check the seal for the gear selector shaft on the side of the tranny. I had one on an 80 vette that a customer of mine could not find and after I did a thorough cleaning of the pan area noticed the fluid coming from this seal and let me tell you it was a pain in @@@ to change. The narrow corvette tunnel made it even that much harder too. If you happen to change this seal make sure you dont damage the lip trying to get it over the shaft. I would think if you have the TCI cast aluminum pan it wouldn't be that anyway the flanges are pretty thick and would seal better than the metal ones.
Jack
08-20-2006 #4
New to Pro-Touring
- Aug 2004
- Flint, MI
- 59
Found the leak
I had a chance to clean up the tranny and you were right, it was the gear selector seal. I was wondering what the procedure is for exchanging this seal and if there are any special tools required? I want to make sure I am not getting into something I can't finish and end up having to have my car transported to a trans shop, especially if I can drive it there now. All advice would be greatly appreciated.
08-20-2006 #5
- Aug 2004
- Texas
- 254
