    Results 81 to 91 of 91
      Jun 2006
      Katy,TX
      Same on I have. I've got the 5 channel AUX box that has a MAP so I can see vacuum at the same time.It's a GREAT unit.Helped me out on several cars and carbs.
      Jun 2006
      Katy,TX
      Here's one of the logs of my recent 11.0 1/4 mile run.
      Delaware, OH
      Quote Originally Posted by Steve68
      What was wrong with the carb??? BG build a bad carb???
      Don't really know and at this point I don't really care. I'm just glad it's fixed!
      Nov 2000
      O-town
      I'm glad your glad!! but it's just strange, new carb with tons of problems,
      Mar 2002
      North California
      Hoooray!
      Dan,
      Awesome news buddy! Well at least your not going too have to
      tear down more into the 572,what a long and pain in the rear
      time you have had.Iam very happy you got all the probs worked
      out on it,now maybe you can enjoy it a little before the big snow
      hits real soon.
      Now..i would like to see a EFI set-up on you ride next summer!
      Great news Dan!
      -Jim
      Jun 2006
      Katy,TX
      From what I hear the BG carbs often have "issues" and their customer service is not always up to par. If you look Summit doesn't carry them anymore.
      I personally have one that worked GREAT out of the box. Others have found metal shavings in them etc. I recently bought a remanufactured 850 from Jegs as a core for some major carb mods.Not sure if reman from BG or another source. Often manufacturers take parts that don't pass initial quality checks and reman them themselves. I expected a carb that had some issues that were corrected in the remanufacturing process. Just a quick check showed air bleeds one that was drilled off center and were different sizes. Took 2 minutes with some drill bits to see they were incorrect. No visible shavings anywhere.
      My current new Holley 850 had no shavings in the bowls but did have them embedded in the gaskets. When I got my Q jet back from The Carb Shop from mods years ago it came with metal shavings in it.
      So quality checks from alot of places have fallen off in recent years. I've had big issues with stuff from Comp Cams also. wrong SINGLE springs in the correct marked box for a set of roller cam springs, cam journal too big to fit in bearings. Most recent my Crower rocker shaft system for Pontiac Edelbrock heads was WAY off. I had to send it back and juggle offset rockers to get it right(I ate the shipping). I have heard BG is trying to improve in this area. You just have to double check everything for a good build.
      Northwestern NJ
      Summit doesn't carry BG's anymore because Barry pulled the line from Summit. Summit was selling the carbs for less than the licensed BG dealers and wouldn't listen to reason about pricing. Barry's dealers were bitchin' up a storm.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Feb 2006
      Dan,
      Glad to hear they got you fixed up. What dealer did it go through? Just want to try and get the carburetor back to determine what was causing the problem.
      Technical Support,
      Barry Grant, Inc.
      www.barrygrant.com
      Delaware, OH
      Quote Originally Posted by Tech @ BG
      Dan,
      Technical Support,
      Barry Grant, Inc.
      www.barrygrant.com
      The dealer I went through was Roby Auto Group in Marysville, OH. However the dealership service manager has returned the carb back to GMPP. If you'd like my GMPP contact please send me PM.
      Feb 2006
      Quote Originally Posted by dhardison
      You've got mail
