Results 1 to 8 of 8
Thread: max stroke ??
10-29-2004 #1
max stroke ??
Hi all,
I have a 400cid sbc block that is half hard block filled that I'd like do do something with and I therefore wonder: what is max stroke with steel rods in a SBC400 block ??
3,875" or maybe 4"??
or should I get a 3,75" cranck and be happy with the 406?
André
10-29-2004 #2
You can do a 3.875" stroke but that is honestly the limit for a factory 400 block.
Someone is bound to hop in here and say that a 4.25" crank will fit. They are right it will physically fit, but the factory blocks are not strong enough to resist the flexing caused by these mamoth cranks.1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
10-29-2004 #3
no 434 then
So making a 434 is out of the question with a standard block then.
what would you go for?
1. 3,75" making it a 406 cid
2. 3,875" making it a 420 cid
3. sell it and go for a dart or motown right away?
If I build it, should I go bananas eg. all forged H-beams stc or just cast and some nice rods and pistons and make a cheaper one?
André
10-29-2004 #4
Starting The Transformation
- Aug 2004
- Alta Loma,SoCal
- 396
Depends on your power goals. I went with the Dart block to save problems when I decide to up the power.
Originally Posted by Tigergutt
1965 Buick Skylark
10-29-2004 #5
- Aug 2004
- Phoenix AZ
- 286
Stock block can be modded to live at 550 hp or so. in the long run its better to start with an aftermarket block. you can spend 1000.00 building the stock one or spend 1800.00 on a good aftermarket.
10-29-2004 #6
- Aug 2004
- north central Iowa
- 503
