Results 1 to 20 of 29
07-15-2006 #1
- Aug 2004
- 378
Replacing a 700R4 with a 4l80E in a 68 Camaro.
What will I need to swap my 700R4 out for a 4L80e and what am I looking to spend?
The 700R4 is just there, has a flexplate on the motor, not really installed and functional, started with it several years ago, before I heard of the 4L80e or this website.
Just looking for a decent junkyard find for now, to run a mechanical speedometer. Plans for a Shrifter(sp) in the future.
Small block 350, 300hp or so, 3:73 or 4:10 rear depending. I don't have any linkage or anything and thought before I went that way, I'd check into a 4l60e or 80e.
Don't have much time to search being deployed,and trying to get as much info to get my car driving as soon as i can when I get home.
Thanks!
07-15-2006 #2The 700-R4 and 4L60 are the same transmission. The 4L60E is electronically controlled and needs a computer, but otherwise it is the same as the 4L60/700-R4.
For your power level you will be fine with your 700-R4.
The 4L80E only comes in the electronically controlled version. (Actually, that's not completely accurate, there is an aftermarket company making them with a manual valvebody.)
It is a bigger, heavier transmission and has more drag, so it's usually not recommended for use until your power levels require it. Of course, if you are thinking toward the future, when you'll have an engine making 700 hp then maybe it's worth it to you.
07-18-2006 #3
- Aug 2004
- 378
Yep, thinking toward the future for once.
Don't want to have to replace the tranny if I end up with the supercharger or big block.
A lot of it will depend on what I can find in better condition and price I think though.
Also, the key idea is the electronic shifting so that I can use a Shrifter.
So is the crossmember and flexplate and all that the same? What contols do I need and for a mechanical speedometer?
Thanks!
07-18-2006 #4
