Results 21 to 30 of 30
Thread: Destroked LS2
09-07-2006 #21
- Aug 2004
- 830
stroke has alot to do with mechanical advantages, high rpm stability, and piston dwell. cant forget about these!.... discuss... man i love this stuff
09-07-2006 #22
- Aug 2004
- 582
I'm wondering if you can elaborate on what you mean by high rpm stability?
09-07-2006 #23
- Aug 2004
- 830
We a shorter stroked engine generally has less rotating mass than a longer stroke engine, and this mass is generally closer to the axes of the crank than a longer stroked engine. This in turn makes the engine less sensitive to imperfections in the balance of the rotating assembly. Any engine builder will tell you they balance to “0” but it is impossible to balance any thing entirely perfect. How ever the hole in my theory is that the benefit if this concentrated rotating mass can be canceled out due to the higher rpm capabilities of a de-stroked engine. A shorter stroke also makes for slower bearing speeds. which frees up power
09-08-2006 #24
- Aug 2004
- 582
Once again we need to clarify whether we are talking purely about a change in stroke, or a change in stroke in combination with an increase in redline to achieve comparable max piston speeds.
For the former, then yes you've decreased rod bearing speeds, but crank bearing speeds are the same and all accessory speeds are still the same. That's all well and good, but I guarantee you that the minor rod bearing friction reduction won't offset your loss of displacement! You're better off running different bearing diameters (see nascar running Honda bearings) than reducing stroke if you're looking to reduce friction losses.
If you increase engine speed, your rod bearing speeds will be basically the same as they were before. Meanwhile, you've INCREASED speed of the crank bearings, resulting in a net increase in friction. You're also driving your pump and all accessories faster. And, probably most importantly, your crank is cutting through oil at a much higher rate. You will experience increased losses as you increase engine speed.
09-09-2006 #25
- Aug 2004
- 830
i agree with what your saying, i was just bringing some other factors into the mix. this conversation could become endless but thats ok. I mean if you throw rod length into the mix it opens up even more doors of conversation
09-10-2006 #26Why the high rpms. V8's are about torque. Longer stroke = more torque. That is what move's the car right. Where can you use 8000 rpm on the street. That high winding motor would get it's ass handed to it by a properly setup turbo motor in a useful powerband. Say 2000 to 6500. I thought the whole idea of the turbo was to pack maximum amouts of air into the cylinders without having to turn the piss out of the motor. Check out ls1tech.com. They argue these ideas constantly.
09-11-2006 #27
