      Jun 2006
      Mason TN
      Question on setting brake bias
      I found some good information doing a search but not exactly what I am looking for.
      I just finished installing C5 rotors and calipers on the front of my Monte Carlo SS and Baer 11" rotors on the rear & I installed an adjustable proportioning valve inline to the rear brakes.
      What I am looking for is any general advice on how to go about setting the rear brakes. I do need to "season the pads first so should I wait until I have some easy miles and braking on the system to make adjustments? Will adjusting the rears require pushing the system to the limits and forcing lockup and then just back down the rears until the fronts lock first?
      Any advice with this is appreciated.
      Feb 2006
      Elk Ridge, Utah
      Exactly correct fine sir hard braking to lockup adjust so that fronts lock first
      You DO NOT want the rears locking first especially in a pannic stop or rain or you will be facing the wrong direction in a hurry and and if your lucky all you will need is a new set of shorts.
      EDIT you could start by taking a lot of rear out and season the pads but that isnt much time on them whatsoever.
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Greenville, IL
      Season Pads?
      How would you recommend doing this? I have heard different opinions. Don't you do several hard stops until you start to experience some brake fade?
      I don't know the proper procedure, but I will need to know for when I get my car ready to drive.
      Just wanting clarification,
      Joe
      Joe there is an article about doing this over at stoptech.com. I don't drive race cars though and find there process a little over the top. Chris
      Greenville, IL
      I will check it out
