Results 1 to 14 of 14
Thread: which refrigerant?
06-21-2006 #1
New to Pro-Touring
- Feb 2005
- Crooklyn, NY
- 74
which refrigerant?
I'm planning an A/C upgrade on my Camaro (original A/C car). I installed new Delco evap and condenser the last time the engine was out. So now I have to get the compressor. I'm going to go with a Sanden/Seltec compressor, but haven't totally decided on which refrigerant to use.
When I first planned on installing the A/C, I figured I'd use R12 since I have a considerable stash of it. But now, I'm second guessing that for the sake of, "what if I run out"?
Problem is, my brand new un-used condenser is a fin/tube type, designed for R12. The condenser came with a tag that says, "For use with R12 or R134a Only. The use of any other refrigerant will void all warranties. If R134A is used, an auxiliary electric fan must be installed."
So this raised an eyebrow and I did some homework. Seems that R134A is best utilized with a parallel flow condenser with more surface area for heat extraction. My fin/tube unit isn't the best for it, and this will probably cause higher head pressures and less cooling effect.
I have already installed the Mark VIII fan and DC controller, so I'm sure I have enough cooling capacity to keep pressure down, but the condenser may still be inadequate.
So this brings me to ask, what would you do? I really don't want to spend another $200 on another condenser...
I took the restrictor plate off to give the Red Dragon a little more Juice. But keep that on the Down Low, it's not exactly street legal.
http://community.webshots.com/user/strokermotor
06-21-2006 #2
New to Pro-Touring
- Jun 2006
- 37
Isn't R134a more readily available. Seems you can just go and get it at walmart if need be. That's enough to make me want to switch over. I think the R12 you have to get from licensed shops or whatever. I could be wrong.
06-21-2006 #3I would recommend staying with R12 as long as possible. It is my experience that you get a cooler air from the R12, as opposed to the new R134A. You can always switch over in the future, if you run out of your stash.
Later - Craig
[email protected]
'70 Chevelle (in storage now, probably will never be back on its wheels again!)
06-21-2006 #4
New to Pro-Touring
- Feb 2005
- Crooklyn, NY
- 74
I am licensed and have an account with a licensed shop. And my stash is about 90 lbs...
06-21-2006 #5Sounds exactly like my situation, engine (except my stash is only about 20-25 lbs) lol. But Im definitely gonna use R12 in mine. Itll cool better, and you probably wont have leaks on your new system, so I doubt youll run out.
06-21-2006 #6Throw a fan in front of the condensor to kick on only when the a/c is running.
Originally Posted by engine
The needs of the many outweigh the needs of the few.
06-22-2006 #7
- Feb 2006
- 478
I this new R12 freeze was compatible with R12? If that is the case, then just use R12 until you run out and then start putting R12 Freeze in it.
06-23-2006 #8
