Results 1 to 11 of 11
Thread: Quick Truck Arm Question
06-19-2006 #1
- Aug 2005
- Saskatchewan, Western Canada
- 15
I have been lurking here for some time, and have decided to post. I have been reading as much as possible and have searched, but I can't find an answer to this question. I am trying to find the virtual point of intersection height of a truck arm setup. The intersection point looking from the top down is a no brainer, but the side view-height is confusing. On paper, the line would go through the center of the arm's front bushing, but what about the rear point. Where is it located? I have 7" of vertical mass (diff tube, mounting plate, and arm itself) to choose from. Thanks for the help.
06-21-2006 #2
- Aug 2005
- 15
Maybe I should rephrase my question. How do you find side view instant center on a truck arm rear suspension?
06-21-2006 #3
Full Blown G-Machiner
- Aug 2004
- Boston MA
- 686
Hell if I know. Call Hot Rods to Hell. Then build a three link.
1967 #s RS
06-21-2006 #4
Starting The Transformation
- Aug 2004
- 194
The rear point would be based on the panhard bar/watts link, like anything else that uses one.
06-21-2006 #5
- Aug 2005
- 15
That would be the roll axis, would it not?
06-22-2006 #6
- Aug 2004
- Boston MA
- 686
No way the instant center is defined by the Pbar. I'm a little surprised that the HTH crew hasn't chimed in on this one.
1967 #s RS
06-22-2006 #7
- Aug 2004
- 957
SVSA is the projected length of the truck arms themselves, in side view (so a bit shorter than the actual length of the arms due to the skew in plan view). The SVSA is NOT what is used to find the roll axis, by the way, but IS used to determine Anti-squat, Anti-lift.
The roll axis is defined by the rear roll center height, (which in most cases is defined by the good ole' boy "J-Bar," or Panhard bar) and the virtual intersection of the convergence point of the truck arms in plan view, projected to side view to establish the height and distance (that probably didn't make sense, but that's how it's found). In other words, draw a line in side view of the truck arm axis, forget about the bushing, just continue to project it forward at the same angle. Figure out the length of the intersection in plan (top) view, and where this length resides in side view on the projected line is the forward lateral restraint point of the system, used to determine the roll axis. Connect this point, to the RRCH, and you have your axis.
I'll bite too though, if you are building a scratch suspension system, why use the Truck Arm?
Mark
06-22-2006 #8
