    Results 1 to 20 of 34
      Jun 2006
      TX
      TIG Welder for body work?
      I am looking for a new welder. I have been welding with a Mig for +3 years now, everything from sheet metal to some heavy duty steel. I would say that I am quite proficient at it.
      I do not know that much about TIG welding though. Can they be used to weld body panels? I just would like to have 1 welder instead of 2. I am guessing the reasons people use the Migs more than the Tigs are they are cheaper, and quicker.
      Any input is appreciated.
      Kyle
      Nov 2003
      Paradise, Ca
      Do a search and I bet you find your answer.
      -Matt
      Jun 2006
      TX
      I did that, didn't come up with my answer. I am not looking for advice on which welder model etc.
      Nov 2003
      Paradise, Ca
      I know I've addressed this before, and I don't really have the time to go into it right now. Suffice it to say TIG is a horrible choice for welding big thin panels.
      -Matt
      Central CA USA
      It would be like welding with an acetylene torch, too much heat on too large an area, panel warping would be a big problem.
      Jun 2006
      TX
      Awesome, thanks for the info guys. Looks like ill be sticking with the MIG for now, since i will be doing more steel welding than other metals.
      Kyle
      Matt - love the sig quote by the way, seen it happen too many times.
      NY
      Actually gas or oxy welding sheetmetal is the way to go if you plan on working weld or panel. They put in more heat but the weld is softer and workable. A mig welded seam can't be worked or anything like a oxy or even tig weld can
      If you plan on doing patch panel work use a mig. If you are going to get into some real metal working high quality stuff use the oxy or tig.
      Most guys mig up a panel and then grind off 95% of the weld and some of the orig metal making a very weak joint. Try hitting it with a hammer and dolly after it is ground down and you will understand. It takes practice to weld thin sheetmetal no matter what type of welder used.
      Jun 2006
      TX
      Well most of the work that i have done is frame work, and welding up sheetmetal to the frame (subframe connectors) etc. i dont really see myself doing too much body work, atleast not compared to other work. Which route would you suggest (tig or mig)?
      hey hotrod68camaro,i have used tig for many years on patch panel work and what the other guys said about to much heat to the thin metal there wrong. with tig you can control your heat more .people who say tig is a bad choice is because there is less skill involved in mig compared to tig and there tig skills are not up there like a tig craftsmen like myself! but tig stuff,ie;machine,footcontrol,tig torch,water cooler.these up the price compared to mig.so more folks use mig. its all about practice!phil
      Central CA USA
      I'm not a body man, so I defer to the others here with more knowledge. I have done some torch and mig body repairs and wheelwell flares. I agree torch welding can work as well or better than mig in the right hands, but takes more skill to control or reduce warping since a torch or tig introduces more heat into the panels. Tig may be similar to torch welding but it doesn't work on thin hot rolled steel, you get loads of pin holes.
      A lot depends on how much effort you want to put into learning techniques. You might want to tac weld with a mig and then tig or torch weld a panel, since the mig is much better at tac welding.
      Read up on hammer welding. If you have the tools, try several methods.
      If you guys have some tips on hammerwelding or TIG use, please post them.
      Nov 2003
      Paradise, Ca
      Quote Originally Posted by 72chevellephil
      The only reason I can see to use TIG on car body repair and construction is to say it's TIG welded. Compared to MIG, TIG takes longer, requires more prep, is more expensive to run (post flow) and requires way too much consentration for a measly patch panel. You may be a self proclaimed "TIG craftsmen" (do you need oversized doors in your house?), but in my eyes, you're waisting time and energy when all that's really required is a quick tack with a MIG.
      The question was not whether it's possible. The question was what process would be the best for all around bodywork. MIG is the answer. TIG should only be used if it's required or if the 'look' is wanted. Beyond that it's a waste of time and money. Hell, I'd MIG all my aluminum stuff if people didn't insist on the 'look'.
      -Matt
      NY
      .....and there tig skills are not up there like a tig craftsmen like myself!
      You just disrespected the WRONG weldor buddy! And on your first post too.
      IBTL
      Boston MA
      Dude called him self a TIG craftsman! Amazing.
      1967 #s RS
      Oakdale,CA
      Hmmmmmmmmm well when I am installing floor pans or patch panels I use a MIG with 75/25 mix gas, but I still use a TIG to install custom body pieces into a panel..........I guess its just what I got used too........Oh and I have an air hose in my pocket that I take out and cool the metal every inch or so.............But Matt's right on the Benifits of miging...........It need much less prep and fit............Just my experience..................R
      Central CA USA
      FCRacing,
      Thanks for the tip.
      How well does the TIG work for tack welding?
      I've done some steel oil pan sumps and bafles with TIG but no body parts.
      Nov 2003
      Paradise, Ca
      TIG on steels is unbeatable for tacking when fitup is good. No filler required so when you run the weld you can't find the tacks.
      Bottom line is if you're worried about warpage, MIG is usually the better choice.
      -Matt
      using air to cool the weld quickly is the wrong thing to do, cooling metal quickly is what we body craftsmen(lol) call shrinking
      Oct 2005
      Okay
      Nov 2003
      Paradise, Ca
      Quote Originally Posted by tired68
      I did this after an hour or so of tinkering, my first time with the TIG.
      That's my point. If you used MIG you would've been done in 15 minutes, grinding and all.
      Either way...you guys can have this body panel welding sh*t!
      -Matt
      Central CA USA
      Nice test.
      It would be even better if you had an old door or larger body panel, then cut a 6" square out of it and weld in a patch. The larger panel has nowhere to go when it's heated and warping would tend to create a bulge.
      A while back there was talk of a special MIG wire that was better for body work with less burn through problems.
      David
