    Results 1 to 20 of 38
      Indianapolis, Indiana
      What wheels are you running with AFX spindles
      What wheels are you guys/gals using with your AFX spindles? I am looking at getting wheels for my project to start mocking up the rear, and am wondering what my options were that have enough clearance for the front. Any help would be appreciated.
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      Feb 2006
      Boulder, Colorado
      Ditto. All I need is to decide on wheels and I can get going with my brake and suspension parts.
      Call out to Tito and the crew at ATS: Anything you can share as far as known setups that work for early f-bodys?
      I know about the templates from T-Classics, but am looking for known compatible 18" wheels with that brake setup that I already have.
      "I got that going for me, which is nice." -eric
      SouthTX
      I have Kinesis wheels and measured before purchasing. I will have plenty of clearance left over with C5 six piston 13" Wilwoods.
      I just ordered my AFX tall spindles today!
      I have chrome Zenetti Fives which I just checked with the Touring Classics C5 Template. Looks like plenty of room. I have the TC Hybrid kit, but now I'm swapping the rotors out for the C5 ones
      Anyhow, the Zenetti Fives I have are 18x8.5 front and 18x9.5 rear.
      If I remember right, I have the 20mm offset which for the front is a little more than a 5.5 inch backspace.
      I can't wait to bolt on the new spindles!
      http://www.bigwheels.net/?location=w...del&model=Five
      Oct 2003
      Arvada, Co
      Quote Originally Posted by Joe_Rocket
      With that much offset make sure you have the short steering arms. If not you may run into tierod to rim clearance issues.
      Brian
      yeah, I had the wheels all mounted up with the stock disk brakes and no issues with the steering arms. I do have the shortest arms which did rub when I tried some 16 inch wheels, but with 18's, seems like lots of room.
      Rowlett Tx.
      FWIW.... I asked & was told the AFX spindle would not work w/the Touring Classics 'hybrid' 13" C4 brakes & that 3.5" BS was the max (my info was based on a 78-up G-body).
      Your right, they won't work with the Hybrid Kit. I am swapping the rotors from C4's to C5's and all will be good at that point. ( I had said that, didn't I ;P )
      Once I've got it together, I'll probably sell my freshly turned down drum brake hubs, the TC caliper brackets and the C4 disks. I even had the hubs and disks zinc washed. ( The AFX Spindles weren't available when I started collecting all this... Well, it's only money. :( )
      3.5 inch backspace? Well, I guess it depends really on the width of the rim. I think most 1st gen guys were running something like a 4.5 BS when using an 8 inch wheel. Not sure... The 5.5 BS is on an 8.5 inch wheel and seemed to fit well with the stock disks. Track width is supposed ot be the same with the AFX spindles. I did dial out the turning stops on the speedtech arms a bit with the stock spindle. But I like the overall fit.
      Oct 2003
      Arvada, Co
      Great, I am glad you did not have an issue.
      Brian
      CCW Classics 17x9.5 w/ 5.75 bs all the way around.
      Stuart Seitz
      Nov 2000
      O-town
      I'm looking into the Budnik Lateral wheels, I still have to work out the BS and brake clearence for the front, I too have the ATS spindles and C5 parts, better call Jon and Jason,
      Woodbine, MD
      so are you all saying that any TT2 wheel...wont work? If thats true...im am S.O.L.
      La La Land, CA
      Quote Originally Posted by SicMonte
      They will work, but they typically require a spacer. We put a set of AFX spindles on Wickedmotorhead's 87 Grand National with a set of TT2 in 17" and it needed a 1/4" spacer to clear the caliper.
      Tyler
      Woodbine, MD
      thats not bad. did his car require longer studs or was it ok with the 1/4" spacer?? I have 17x8 fronts with 4"bs..and i already have the SC&C stage 2 kit....the spindles would just add on to that.
      I ordered Boyd's for mine 18x8 with 5" BS - on Noel's suggestion I asked Boyd to insure 1" caliper clearance on the wheels. You might give Noel a call.
      Feb 2006
      Boulder, Colorado
      Bump.
      What are folks running with their AFX spindles?
      Eric
      69 Camaro - LT1 w/ 700R4, DSE springs, swaybar and Konis. Still rockin' it old school with 15" wheels and 60 series tires.
      Dec 2002
      Lost Wages, Nevada
      HRE C20... 18x9.5" on all four.
      Feb 2006
      Boulder, Colorado
      Bump. Any others out there??
      Eric
      Jul 2001
      Calgary, AB
      HRE Comp20's - 18 x 8.5" with 5.9" BS (may not work for everybody)
      And they showed up at ATS today
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
      Feb 2006
      Somewhere in the Pacific Ocean
      I'm using Forgeline WC3's 18" x 8" with Baer GT Plus brakes (basically their C5/C6 caliper w/ Eradispeed 2 pc rotors)
