Results 1 to 20 of 32
06-08-2006 #1
LowBuckX now has C6 front rotors...
Just put some 2005 Vette 12.8 x 1.26 rotors up front with some 1972 1/2 ton calipers.
The brackets where fun to mod but worked out perfect.
I made a 3/8 bracket that mounted to spindle and locates old bracket off that
06-08-2006 #2Lots of room in my rim but these rims are made for newer Suburban and Tahoes
What do you think.
Ive seen the pbdcbb and Mr Pozzis CBB and sorta combined then
the pbd-cbb is stock calipers with c4 13 x 1.1 rotors or the 12x1.25 c4 rotors with the 72 calipers.
If you care and want something clarified for you just ask.
Just for your fast referance Rotors are $30 each Calipers are $16 each At Napa (used stock calipers as cores) Bolts from McMaster carr $6 So that is $98 for my front brakes
Rear Discs set up was $260 (with master)Nothing says "I built this" better than tool marks and dykem blue..
06-08-2006 #3
- May 2005
- St. Augustine, FL
- 1,529
Dam thats cool. And so cheap.
Andrew Petty
06-08-2006 #4I remember when you were asking about options... this looks like a good setup. The brackets and spacers pushed out your rotors a good distance, but that makes the fitment of the late model rims easier I suppose. Never would have thought about the truck calipers; good find!
I thought I got away cheap on my LS1 setup ($200ish), but you did much better. I tell you, cutting down the original disks for hubs saves a bundle.
06-08-2006 #5
