      Rear Sway Bar question...
      Will have "B" body spindal (69 chevelle), and was told NOT to run a rear sway bar....was I told right?
      Greenville, IL
      What are your plans for the car. I don't think I would go w/o a rear bar, but I am by no means a suspension expert.
      Let me clarify a little better...with negative camber I'm not supose to run a rear sway bar???? Any truth to this?
      Nov 2002
      state of confusion
      I think whoever told you not to run a rear bar was being cautious, as the need for a rear bar (and/or its size/configuration) depends on quite a few other things. Spring stiffnesses front & rear, front bar size, wheel/tire package(s), static alignment settings, etc.
      To be fair, if you haven't touched anything other than the spindle, you will understeer to a lesser degree at the limit than OE, though whether this effect might wander all the way over into oversteer territory is not at all certain.
      Norm
      Gone but not forgotten dep't:
      My plans (which change from day to day) are to go with Hotckis TVS (BB Kit), Hotckis Upper A arms, w/ B-Body spindals. So...this may help fill the missings questions. Thanks for the help!!
      My first reaction was to tell you to ask Hotchkis since you're using their equipment exclusively and therefore probably know what the package needs or doesn't. Although they're going to be a little biased if they think they can sell you more parts by saying you need it.
      But then I thought, "its not hard to take it off. Run it both ways (w and w/o your stock bar) and decide what works best for your situation." Depending on your combo, you may even decide to run their rear bar after all.
      When I used to drag race, I would try to swap parts at the track (when practical) so I could quantify the benefits. The Lingenfelter air intake for LT1 Camaros knocked almost .4s off my quarter! Swapping the cat (had it specially flanged) for a test pipe showed negligible improvement (it went back on).
      Good idea AMCMike.
      Ok, now the next question...What all do I need to do to make that B body spindal work (with an A body)? Ball Joints, ext...
