Results 1 to 12 of 12
Thread: exhaust help
06-05-2006 #1
- Jan 2006
- 69
exhaust help
I posted this in the exhaust section but I guess it is pretty slow over there. So anybody????
I am going to order my exhaust and want opinions on sound and performance on 2.5 or 3 inch exhaust. What would be better on a stock ls1 with mac headers in a 67 camaro. I am looking at flowmaster 40s
thanks67 camaro restoversion
http://photobucket.com/albums/v643/skinner21/?sc=2
06-05-2006 #2
- Sep 2005
- Central Illinois
- 152
I can't see why you would need 3" with a stock LS1
'68 442 convertible
5 SPEED - EFI
'66 442 Hardtop
in process
06-05-2006 #3
- Jan 2006
- 69
what about sound
yea thats what I suspected and I even suspect that the ls1 may even be better off with the 2.5 but I dont have any data to back that up but would it sound significantly better with 3 inch?
06-05-2006 #4I think you're going at it from the wrong angle - go with the 2.5 and if you want a different sound change out the muffler.
Originally Posted by ls67
06-05-2006 #5
- Sep 2005
- Central Illinois
- 152
3" pipe will make it sound like 3" pipe.
There's so many variables when it comes to exhaust sound.
Mandrel bent pipe will make it sound louder than crush bent (muffler shop) pipe too.'68 442 convertible
5 SPEED - EFI
'66 442 Hardtop
in process
06-05-2006 #6I would go head and do a 3inch system,If it needs backpressure change the muffler out.
06-07-2006 #7
- Jun 2006
- Torrington Ct
- 25
LS1 works very well with a 3'' exhaust and X pipe
06-07-2006 #8If you want it louder go 3" If you want it quiter go 2 1/2" It will have a different tone with 3"
06-07-2006 #9Go with a 3'' Dr.Gas x-pipe, 3'' Spintech Sportsman XL and 3'' Torque Tech tail pipes. AWESOME sound at idle and at wot, you just would not believe the sound. Nothing like I have ever heard. I am really satisfied with my choices.
69 RS Rat. Ocean View, De. 19970 If you wake up and you can put your feet on the floor, IT'S A GOOD DAY!!!
06-10-2006 #10
- May 2006
- 33
2 1/2" is good to about 450 hp. 3" is good to about 550 hp. Both in a dual configuration. X-Pipe if you have the room. They work in a wider RPM range than a standard H-Pipe. Hope this helps.
06-10-2006 #11
New to Pro-Touring
- Apr 2006
- 74
for a "stock" LS1 a prefab flowmaster kit will work just fine. the american thunder series from personal experiance on a car i built sounds awsome and except for the header flange fab is a bolt in deal in your driveway.
10-27-2013 #12
- Jun 2013
- 9
