    Page 2 of 2 FirstFirst 1 2
    Results 21 to 30 of 30
    1. #21
      Mountain View, CA
      IC = Instant Center
      True T.
      My blog
    2. #22
      Nov 2002
      state of confusion
      It still rotates about its side view IC, though perhaps not a whole lot. Then again, there isn't a whole lot of difference between a 50" side view virtual swing arm and a 50" real swing arm (with a physical arm and pivot) . . .
      Norm
      Gone but not forgotten dep't:
    3. #23
      with sour suspension having not much more then 3-4 inches of travel max, i cant see the toe changing a noticable amount
    4. #24
      Boston MA
      rat,
      TLWiltman did a pretty good of explaining the relationship between rear camber and toe. To recap...
      With the pinion angle at 0 and 1 degree of negative camber,the top of the tire is pointing towards the center line of the car in the verticle plane. If the pinion angle is at 90 degrees the pinion is pointing straight up your 1 degree of camber is now 1 degree of toe out(the rear edge of the tire is pointing at the center line of the car in the horizontal plane). If the pinion is further rotated to 180 degrees (pinion pointing at the rear of the car) your degree of negative camber is now 1 degree of posstive camber.
      Because your truck arm rigidly mounts the axel, pinion angle will change as the suspension moves the axel up and down. Any change in pinion anlge will correspond to a change in the camber /toe relationship. Hope that helps.
      edit: three new posts by the time I was finished
      1967 #s RS
    5. #25
      Jun 2005
      Grapeview, Wa
      Basically, if you have 0 toe at 0 pinion angle, and then add some negative pinion angle you should be perfectly OK. The big thing is that you NEVER have toe out. Also, with a T/A rear suspension, the pinion will rotate upwards a bit under acceleration due to the rubber bushings at the front.
      Tad
      '73 Camaro RS in progress.
      L-D 3-link (working on the front end, too), SCP spindles, Wilwood brakes. I'll be working on it for A WHILE!
    6. #26
      Feb 2006
      s.f. east bay california
      I don't use rubbers
      I don't have rubber bushings in the trailing arms. With the length of the arms the dagree change from travel is about 15-20. Is that really enough for me to be worried about toe out and what would you recomend I have the pinion angle set at to minimize that possability. Given a 1 dagree camber set for each wheel.
      Dog will Hunt
    7. #27
      are you running solid bushings or just somthing harder then rubber? im building a rear suspension and im trying to decide what to do with that.
    8. #28
      Jun 2005
      Grapeview, Wa
      Quote Originally Posted by RobM
      Options for truck-arm mounts...
      -Rubber
      -Speedthane-compounds range from hard to soft. Often used for tuning by NASCAR teams.
      -monoballs
      Pinion angle. If your 1 degree camber is at 0 pinion angle, I would think... -3 to -4* pinion angle should work. With monoballs, you might be able to reduce that to 2-3*
      Tad
    9. #29
      Portland Oregon
      I would not suggest it. Puts abnormal wear and force on the factory Axle bearings. Generally we use about 1-2 degrees neg. Camber on the axle tubes. But we are using floater housings with a rather large wheel bearing and they are easier to inspect and change.
    10. #30
      Nov 2002
      state of confusion
      More than 1° and you do need to do things a bit differently.
      But I'd rather have about -0.75° than zero, and absolutely do not want to see any static positive camber back there. Having it go slightly positive dynamically due to axle roll means that you're already giving up some grip on the end that you have no direct control over - with this occurring at the time you need all the grip you can find.
      Norm
