    Results 1 to 11 of 11
      Jul 2001
      Detroit, Michigan
      Welding holes closed...
      I have to weld 4 holes closed on my subframe. They resulted from a bad Guldstrand Modification (the drill bit walked on me). What is the best technique for doing this? I have a Miller 135. Thanks.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
      Apr 2004
      Cedar Rapids, IA
      Use a larg piece of copper on the backside and start welding. Weld dosn't stick to it.
      Mar 2004
      Mid-Michigan
      Are you going to have to redrill the holes? Just welding them closed will make them even harder to drill. I would have to see the area you have to work with but you may want to consider cutting the area out and welding in a new piece to give you room to drill...
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Houston Texas
      if you don't have acess to the backside to back it up with copper then just use your standard settings for the thickness of metal and start filling the hole in a circular pattern untill its completely full. Grind smooth and redrill. If that doesnt work then i would do what mr. astroracer said.
      Zach
      68 Camaro - never to be finished
      06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
      http://www.youtube.com/watch?v=KmB2y7uX38I
      Jul 2001
      Detroit, Michigan
      Mark...can you explain why they would be harder to redrill after welding them closed? Is the material that gets deposited during welding more difficult to drill through?
      I'll post a pic of the area in here when I get home from work today.
      Thanks.
      Project: Next Year
      Mar 2004
      Mid-Michigan
      The weld is a lot "harder" then the virgin steel. If the new hole is half on/half off the weld it will be near impossible to keep the bit centered due to the softer parent material allowing the bit to walk. If you had access to a Magdrill the ability to maintain the bit on center would be improved. Another problem is incomplete welds, air pockets or voids which will grab the bit.
      Not that this is impossible to do but the inconsistancies and harder material make drilling it more difficult.
      Mark
      Mark:
      Oct 2005
      Odessa mo.
      You could partially weld the hole shut. Then use a pointed carbide burr in a die grinder to ream it out to the proper size and location.
      Nov 2004
      Colorado
      Quote Originally Posted by astroracer
      Mark
      The weld is harder than the hinges on the gates of hell.
      Jul 2001
      Detroit, Michigan
      I'm going to weld the holes closed and just leave it. I plan to upgrade my spindles to the tall ATS/AFX spindles in the near future. Then I won't need to do the Guldstrand Mod. Thanks guys.
      Project: Next Year
      NY
      Quote Originally Posted by EFI69Cam
      What do you use to weld? 10018, hard facing, or tool steel???
      May 2006
      Staten Island, NY
      Country Flag: Argentina
      pilot holes, pilot holes, pilot holes!!
      "it's never too late to have a happy childhood!"
      Rudy M
