    Results 1 to 17 of 17
    Thread: Front hoses
      Front hoses
      I am installing C4 calipers on the front of my 64 Buick Special with 13" rotors. What should I use for hoses? Thanks
      Nov 2000
      O-town
      braided or rubber, I bought braided,
      Rubber is fine for this application.
      Nov 2000
      O-town
      It comes from GM that way, I had some extra money so I bought Goodrich lines from Baer, and they were too much,
      Were your hoses custom or do you know of a specific hose that will fit?
      Nov 2000
      O-town
      I think I bought them for a PBR caliper
      Marshall , MO
      you might try lines for a 69 camaro I think that is what has been used for the other A-body conversions.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Thanks to all.
      Dublin, CA
      I ordered mine from Summit using Earl's Performance Pluming parts. They make a generic braided hose with 3AN swivel female on one end and a 10mm banjo on the other for $18. The other parts needed: 10mm 1.0 banjo bolt (.425" height) and a tubing adapter (3AN male to 3/8" female inverted flare). Total cost for both sides was around $55 and the hoses meet DOT requirements. This was for a PBR caliper, hope that helps.
      Thanks, barno.
      Scottsdale AZ
      Try Noel at Touring Classics or Classic Tube.
      Either one knows brakes!
      I received my new hoses last night and they fit great. I ended up with stock 91 Vette hoses. Now I am trying to find the 10mm banjo bolt.
      Nov 2000
      O-town
      Dealer! and get factory brass crush washer, aftermarket is junk,
      Dublin, CA
      Why do you say that Steve? I have some 10mm 1.5 from Earls, but have not torqued them yet as my hoses are back ordered. Have you had leaking problems before?
      Brent
      Nov 2000
      O-town
      Well, maybe not Earl's but I got some new/reman calipers for a friends 00 Blazer, and for the life of me couldn't get the lines to quit leaking, hunt the old ones put them on and the flooding was over, buddy own a shop he says I never use the sheeott washer, just a little FYI,
      Just think, just like Jason(Fuel) new paint and brake fluid, it don't mix, includes skin!!
      Aug 2005
      Hamilton, NJ
      I'm not sure why, Steve, but the problem you described I have seen many times. We would change hoses or calipers on a car and they would leak until we used the old brass washers. Then problem solved. I can't figure out why the new washers don't always properly conform (that is my guess as to what is happening). I mean brass is pretty soft.
      Scott from NJ.
      Vent Windows Forever! ...
      The braided lines themselves are fine, though not nearly as flexible. You can't make tight radius bends with those.
      Yeah, I do not care for the aftermarket stainless banjos and bolts. I really think the bolts are a little short. There's not many threads showing once you put it through the banjo with two washers. I had to really crank those suckers down to get a seal. I'm sure if I go any tighter I'll strip the threads in my new PBR's. I just don't feel comfortable with the setup.
      If I can find some stock PBR Caliper bolts, I'd like to compare the lengths with those of the stainless bolts in the braided line kit. I may also switch back to rubber hoses with the grooved brass ends. I think those groves make a big difference in sealing.
