    Results 1 to 13 of 13
      SoCal
      sending units going bad?
      After getting my car back from the body shop, neither the water temp gauge nor the electric radiator fans are working. Both have separate sending units - could they have gone bad just sitting around for a year? It's strange that all other gauges work fine, and when I turn the ignition to accessory I can see the needle of the water temp gauge move so I know it's getting power.
      England
      change the sender as the last thing you want is those playing up
      The Netherlands
      Country Flag: Netherlands
      Sounds like a ground problem...body shops tend to remove panels and everything attached.......if they painted your car and put the grounds back it could be possible the wire is not contacting metal anymore...
      just a thought
      Martin
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      SoCal
      Quote Originally Posted by Martin71RS
      just a thought
      Martin
      Yeah, I suspected that although all the other gauges seem to be fine. I will have to definitively rule that out though.
      SoCal
      That makes more sense now that I think about it - if the ground wire from the engine block to the frame/body is gone then that would probably do it...
      The Netherlands
      Remember it will also affect your ignition and starter then!! Never underestimate the power of good grounds! (you can never have too many)
      Martin
      1st 2nd
      SoCal
      Well dang, that wasn't it... the ground wire was there. Arrgh.
      SoCal
      ok well I grounded both wires going to the sending units to the block in turn, and the fans ran and the temp gauge maxed out - so it looks like the sending units...
      Is it bad to use teflon pipe joint compound to seal the threads? They did work initially...
      Waverly, Kansas
      The manufacturers typically say not to use teflon tape as it provides a good seal but it does not ground out against the block (i.e the sending unit threads are not in direct contact with the block). That is how the sending units are actually grounded - via the block.
      SoCal
      I'm not using teflon tape but a paste.
      This problem is still with me... thought I had it solved since I found a ground wire off the ignition, but the gauge and fan are still not working. I'm getting a new sending unit to test, but does anyone have any other suggestions?
      SoCal
      Arrgh, I will (embarassingly) update this for the sake of others who may find this post in a search....
      It turns out that they had switched the wires to the two sending units.
      Feb 2006
      Elk Ridge, Utah
      Heh leave it to bodyshops
      They need to learn how to repair cars as well as move metal and spakle pannles
      I have seen cars come to me from bodyshops with all sorts of electrical problems 50% caused by the bodyman the other 50% the accident cutting harnesses
      Metamora, Illinois
      Quote Originally Posted by rockdogz
      No need to be embarrassed. Just be glad you found the problem and fixed it.
