    Results 1 to 12 of 12
      Olympia Wa
      DSE's new subframe?
      I haven't been here long but does anyone know someone at DSE? I'm drooling over info on when their new subframe will come out. Anyone have an inside scoop?
      Jacob
      Las Vegas, NV
      Didn't even know they were making one. Would be interested in info myself!
      Doug
      67 Camaro - Project: Retribution
      "Honda: The most efficient means of converting gasoline into noise without the side effect of horsepower."
      Santa Barbara
      I spoke with Kyle today and I believe he said it will be out in January or thereabout. Should be a sweet setup. He said that some current components will be used but it will pretty much be all new.
      Las Vegas, NV
      Any chance you could round up a guesstimated cost at this point or is it still too early to tell? Would be interested if it was...er... "competitively" priced. Tightwad, frugal, call it what you will.
      Doug
      Aug 2001
      Wilton, CA. (Sacramento)
      It should be competitive with the Wayne Due front end as that's the quality and handling they're going after.
      Jody
      Santa Barbara
      I believe kyle said around $5,000.
      Jan 2004
      NW Suburbs, Chicago
      Quote Originally Posted by camcojb
      Jody
      I thought i read in the other topic about the subframes that the DSE fully modded stock frame was better than Waynes C4 setup already as far as handling?
      are you comparing to Waynes C4 or C5?
      Olympia Wa
      Man I can't wait until that thing comes out. I want to be the first Firebird on road with DSE's new setup.
      Moebrawlz- DSE's modified sub frame from what I’ve read is comparable to Wanes C4 or C5 setup as far as handling but Wayne's set up has rack and pinion steering. From what I’ve heard DSE's new sub frame is a completely new frame with rack and pinion steering. A notch above their fully modified setup, lower, sturdier, better handling, rack and pinion steering. It will be right along the same lines as Wayne’s C5 setup but in my opinion better. I last herd they will also still try and keep spindles that have a load of brake options, which is always a plus.
      Anyone here work for DSE. Think I can get a discount for this last post…
      Jacob
      NJ
      chassis
      when are they going to make 70 camaro stuff
      Mar 2003
      Make it big
      Any pics of the frame?
      -David
      Ttt?
      Sunny San Diego
      any chance of a group purchase for the frame? sounds like many people will jump at the chance if Kyle can give a 10% off for a group purchase on the frame.
