Results 1 to 13 of 13
Thread: Kenne Bell LSX blower in 1st Gen
05-05-2006 #1
I'm not sure if this should be here, or in the LSX forum but here it goes. I have decided to do an LS1/T56 conversion, the motor and trans are on the way. Kenne Bell has a new LSX blower on the market that I am very interested in. Here's the link: http://www.kennebell.net/supercharge...gmCorvette.htm . Over 500 RWHP and TQ on a stock LS6. That's pretty impressive. It's intercooled but it's still kind of scary that they are putting 7 psi of boost to a motor with almost 11:1 compression on pump gas, but Kenne Bell has a very good reputation and do their homework from what I know. I am curious if this will fit under a stock height cowl hood, it doesn't look that tall. Anybody have any info on this system?
Here are my thoughts for the engine combination:
2002 LS1 short block (stock)
AFR 205 heads with 76cc chambers, or possibly ported 6 liter heads to lower compression (I know it may not be neccesary, but it makes me feel better about boosting the stock bottom end)
Small cam (218/228 maybe?)
90mm throttle body
1 3/4" headers from Stainless Works or Hooker
What do you think of this combo? How much RWHP do you think this will be good for (I'm guessing at least 550)? Will I be pushing the limits of the stock short block? I'm trying to do this on some sort of a budget
so I'd like to avoid tearing into the rotating assembly for now if possible. I'm new to the LSX thing, so any advice is appreciated. Thanks,
Andy
05-05-2006 #2It sounds like a sweet setup! Kenne Bell does do their homework when it comes to supercharging period. 500 to 550 RWHP sounds about right on a stock lower end. I ride around in KBs test cars all the time and I do have to say that there is nothing like a KBd 2500 suburban w/stock engine and 500RWHP on 8lbs of boost running 13sec 1/4miles on 20s! This suburban has had the supercharger on it since it left the showroom floor, it currently has 60,XXX some-odd miles on it and is running strong!. I honestly think that you will be fine running a stock short block.
brad
05-06-2006 #3That's what I'm hoping also. Their dyno charts show 525 RWHP and 500 RWTQ on a stock 02 Z06 (only mod is cold air box). I think that's enough power for me. I have an LS1, so I will need to get better heads to match their results. I also only have access to 91 octane here, so dropping the compression into the mid to high 9's seems like a good idea. It doesn't seem like I will need much cam, but I would like my car to have some lope to it. My last gen 1 small block had AFR heads and a 242/248, .540/.568 roller cam, and I loved the idle (sounded good anyway). The 42 lb injecters supplied by Kenne Bell are good to 560 RWHP I think, so no need to go overboard on cam/power. Any suggestions on the cam? I'd like to keep the rev limit to 6500 to help save the rotating assembly.
Originally Posted by 72NovaSS
05-06-2006 #4
- Aug 2005
- Asheville, NC
- 87
90mm TB & new intake to run that TB is not necessary for those hp numbers with boost, so you could save some cash there. If you plan on going over 7#, make sure you replace the head bolts.
05-06-2006 #5
