      Tomball, TX
      Welders - Please Critique my Welds!
      Anyone who has any TIG experience, I'd love to hear your thoughts/comments/tips/etc on two T-joints I welded at my welding class last week. I'm in my second welding class at a local junior college, and I've been working solely on TIG the last 5 or 6 weeks. It's taken me about 2 classes to finally get my T-joints looking halfway decent (IMO). Here's a couple I did. I apologize in advance for the crappy pics...I was having a lot of trouble getting any decent ones.
      I've done steel, stainless, and aluminum, and stainless is by far my favorite to weld so far. On the stainless piece, I know I got the right side a little hot since it's kinda grayish colored. I'm hoping to start TIGing on stainless 2.5" tube pretty soon because I wanna build my own exhaust from the headers back. It'll be a big undertaking, but I'm a pretty patient person when it comes to this kind of stuff.
      The first is an A36 1018 CR Steel using a 2% thoriated (IIRC) tungsten and 3/32" filler rod.
      The second is a 1/8" 304 (I think ) Stainless Steel also with 3/32" filler. Believe it or not, that was the first T-joint I tried with stainless, so I was pretty happy with the result.
      Anyway, let me know what you think! Thanks guys!
      Ryan
      '68 Camaro (slowly coming back together...very slowly)
      Houston Texas
      By no means am i an expert, but i would try using a bit smaller filler. something like 1/16" What size Tungsten are you using? Also instead of washing the puddle around you might want to try keeping it in the same place and just dabbing the filler. (will be easier if you switch to a smaller filler) Other than that it looks great, no undercutting and you now the heat.
      68 Camaro - never to be finished
      06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
      http://www.youtube.com/watch?v=KmB2y7uX38I
      Nov 2003
      Paradise, Ca
      The side to side technique you're employing right now is used for cover passes on multi-pass welds only, and is normally done much colder than the root and fill passes. For a single pass weld, do not use this technique. All you're doing is multiplying your chances of not getting penetration at the root and putting more heat into the weldment than necessary. Also increasing your chances of undercut.
      Atleast you can go in a straight line. That seems to be beginner's biggest problems on average.
      And like Zach said, smaller filler. In the first picture, the start of the weld looks way too cold, which is probably a combination of filler size and the weave pattern. could be the picture too though.
      Also, 1018 and A36 are two different alloys.
      -Matt
      Tomball, TX
      Zach, thanks for the tips! I'll try that out at my next class.
      Quote Originally Posted by Matt@Lateral Dynamics
      Matt, thanks for the advice. Is the proper technique for a single pass weld to do a straight pass and dab the filler into the puddle (rather than using a weave with a lay-wire technique, like I was doing) like Zach mentioned?
      Also, what about the HAZ? I've been told that you don't really have to worry about that until you're getting really good and wanting to produce very high-quality welds, but that just doesn't seem true to me. I'd think that it would be important no matter what (esp. in stainless). Your thoughts?
      Thanks for the comments guys...keep them coming!
      Ryan
      Nov 2003
      Paradise, Ca
      Some guys like to use 'lay wire', but I like to physically see the arc get into the root before I add filler. Much more control that way too. Also, with TIG, moving the torch along in a straight line should be done on any pass in a multi-pass weld except for the cover, if applicable. See attached.
      Perfect practice makes for perfect performance.
      -Matt
      Tomball, TX
      Matt - damn, that is a really nice weld in that pic you attached. Can you tell me how it was done (technique, filler, material, machine settings, etc.)? I'd love to be able to get to that point with my welding skills.
      What do you think about washout/washover (can't remember what it's called - whatever the technique is where you go back over a pass with just the torch to improve the look of the bead)? My welding prof said people do it basically just to make the weld look nicer, but I have to imagine that has some impact on the quality/strength of the weld. I know he said they won't grade students' welds that have been washed over.
      Ryan
