      May 2006
      Florida
      68 Camaro/Wilwood/Globalwest-Backspacing
      68 Camaro
      OK, I did a search and saw a million replys for similar posts. Just curious if anyone has or had the setup I'm going with. I'm putting on a Global West stage 4 kit(new upper/lower fronts, new leafs rear-lowers about 1 inch overall) with Wilwood disc on the corners.
      I plan on using 17" rims. Does anyone know what the proper BS would be so no rubbing occurs.
      I've read the 8-8.5 up front with 4.5 BS and 9-9.5 rears with 5.5 BS.
      Opinions/Facts?
      Jun 2002
      Oregon
      go with:
      17x8 w/ 5" b.s. 245/45/17 tire
      17x9.5 w/ 5.5" b.s. 275/40/17 tire
      This is the widest combo that works on a stock subframed first gen camaro with discs and stock width rear axle....
      Tony
      May 2006
      Florida
      Thanks. Pretty much what I've encountered. I was just curious because I was told the wilwoods change the offset.
      SouthTX
      They do. I was told by Wilwood +3/8" each side.
