    Results 1 to 16 of 16
      Feb 2006
      Southeast Louisiana
      Mono vs. Multileaf Shock Plates
      What is the difference in mono leaf and multi leaf shock mounting plates? Can mono leaf plates be used when converting over to multi's?
      zachary louisiana
      i dont knwo the exact answer but everytime i see a post about people converting they cant find the multi leaf shock plate to complete the swap....but i dont know for sure...i remember seeing dse selling some
      hey man i lost your number again i need to save it in my phone can you give it to me again thanks
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      Feb 2006
      Southeast Louisiana
      pm sent
      May 2002
      Northern California
      It works for me. But I think they are thinner lateraly by a very small amount. sorry, just narrow.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Chesaning, MI
      I thought that the mono leaf plates have the shock mount lower by 2 or 3 inches. I believe there's info on Pozzi's website about this.
      Jan 2003
      Arizona
      Don't do it. The perch is designed to surround all four sides of the leaf spring (in conjunction with the shock plate). Mono-leaf perches are shorter in depth since they only need to surround a single leaf. When using mono perches with multi springs, the sides of the leafs are exposed, so the u-bolts carry all of the load. The u-bolts are only intended to clamp the perches to the shock plates--not carry the entire load. Those bolts could shear.
      If you are not in a position to convert them (welding is required), then at the very least, build some simple spacers to fill the gap between the perches and the shock plates.
      ________________
      Steve Chryssos
      Nov 2004
      Colorado
      Quote Originally Posted by streetfytr68
      I've wondered about that when I see mopars and late trucks that just have the flat spring perch that offers no latereral support.
      Chesaning, MI
      Thanks. I ordered a set of the multileaf plates last night from Rick's First Gen. just to be safe.
      Jan 2003
      Arizona
      You rock!
      ________________
      Steve Chryssos
      May 2002
      Northern California
      Are we talking shock mount plates or spring perches? doi
      Jan 2003
      Arizona
      Both.
      ________________
      Steve Chryssos
      Feb 2006
      Southeast Louisiana
      Let me re-phrase my question. I will be converting over to a multileaf spring and was wondering if the shock plates for a mono leaf set-up will work. I know the spring perches are different, and I will be removing the existing mono perches and welding the new multi leaf perches on. It does appear to me that the shock mounting brackets hang lower on the mono plates. Bottom line is do I need to order the multileaf plates when I convert over?
      Chris
      Jan 2003
      Arizona
      Oops! Shock plates are the same.
      ________________
      Steve Chryssos
      May 2002
      Northern California
      Mono are abit narrower. Tad, schosh, etc
      Chesaning, MI
      The mono-leaf shock mounting plates have the lower shock mounting hole roughly 1 inch lower than the multi-leaf plates. The mono plate is also made of thinner material steel than the multi-leaf plate. A few of the catalogs offer "shock extenders" for using the mono plates w/ multi-leafs. Just a few things I noticed.
      Fontana, CA
      I would just get the Multileaf Plates and be done with it.
      Nick R.
