      La La Land, CA
      Need math confirmation on wheel offset
      Hey guys, I have a interesting wheel/tire combo to figure out.
      Here's the specs on the car:
      1967 Camaro
      Front hub to hub width: 61"
      rear hub to hub width: 63"
      front rim size: 20x11
      rear rim size: 20x13
      So far I have front with a 20x11 with 4.5" of backspacing, and 20x13 with 6.5" of back spacing.
      He wants the wheels and tires to stick out at least 2" on each side so we can add flares to the car.
      The stock sheetmetal is 71" in front, and 72" in the rear.
      This gives me 4.5" from the rear hub to the rear 1/4 panel, and 5" from the front hub to the front fender.
      Can someone confrim this for me?
      Tyler
      Alta Loma,SoCal
      i GET AN OUTSIDE WHEEL TO WHEEL MEASUREMENT OF 74" FOR THE FRONT(1.5" STICKOUT PER SIDE) AND a 76" overall width for the rear(2" stickout per side).
      1965 Buick Skylark
      La La Land, CA
      Great! I just wanted to make sure I wasn't on crack.
      Anyone else care to take a shot at this?
      Tyler
      Mar 2003
      Make it big
      Tyler what size tire are you gonna use on the 20x13?
      -David
      Pittsburgh, PA
      Check Again
      Tyler,
      I come up with different numbers than TurboLark.
      Front: 12"-4.5"=7.5" 7.5"x2=15" 61"+15"=76"
      Rear: 14"-6.5"=7.5" 7.5"x2=15" 63"+15"=78"
      You need to remember that a wheel is usually one inch larger than the actual wheel width (beed to beed) this is also taken into consideration measuring backspacing.
      Shane
