Thread: DSE mini-tubs and axle mods
04-22-2006 #1
New to Pro-Touring
- Jun 2005
- 6
I have a couple of questions hopefully some of you veterans out there may have already had to address. I have a 67 Firebird that I am thinking on installing the DSE mini-tubs. I am considering their complete kit that also comes with leaf springs and their offset shackles. My first question is if I use their leaf springs and the offset shackles will it be necessary to relocate the spring perches (move them inboard) on my axle? Second question: With the installation of the mini-tubs is it recommended that you run a narrowed rear axle width? For you guys that have done this min-tub install on a 67, what axle width dimensions are you running (wheel mounting surface to wheel mounting surface)? Thanks for the help.
04-22-2006 #2
- Sep 2005
- Orlando
- 296
I can't advise you on the leaf springs, as I'm switching to their Quadralink, but the axle narrowing is up to you. If you don't narrow it, the wheels will have high offset (like a late model) and won't have much lip.
I ordered my wheels with the backspace I wanted (18x12 with zero offset), when they show up I'll mount the tires, mount them on a makeshift axle and center them in the wheelwells. Then I'll narrow the axle accordingly.
If I didn't want to narrow the axle, the backspace would have been around 7.75 inch, not leaving much of a lip.Chris
67 Camaro single turbo LSX/T56 -V2.0 underway
06 AMG CLS55 2.9 Whipple, 5.6 forged Darton MID
06 AMG E55 w 63 conversion 2.9 Whipple
99 FRC Corvette pretty in pink
04-22-2006 #3
New to Pro-Touring
- Jun 2005
- 6
Whistler, thanks for the reply. I imagine the quadra link set up will provide suffucient clearance to fit a 12" wide wheel with zero offset and still have the tire clear the link bars and the coil overs?
04-26-2006 #4
