Thread: What to do, what to do?!?!
First...I figured open p-t would be the best place for this since it comprises suspension, transmission, paint and body, and potentially other categories all together. Sorry if I chose wrong.
Alright so I'm getting ready to put together a pretty major project on the ol' formie.
Here's what I WANT to do...not sure if the budget's going to allow for all of it, but this is just the planning stages.
Suspension
-Air Ride AirBar rear suspension kit
-AirRide shockwave double adjustable “strong arm” front suspension kit
-AirRide Ridepro-e Air control/compression system
-Flaming river power steering box
-Misc Lines, etc.
Chassis
-G-Braces
-Subframe connectors
-Solid Body bushings
Clutch
-Lightweight aluminum flywheel
-Modular bellhousing
-Street twin clutch
-Adjustable ball stud
-clutch linkage
I would also be cleaning up and redoing my front subframe while it was pulled for the body mounts.
My question is, what else SHOULD I do that relates to these projects? I.e. Should I go ahead and replace my rag joint while I'm doing the steering box? Stuff like that.
Also, is it possible to pull the entire front subframe on a second gen with the motor and trans still attached to it ? That would be so convenient for me, if it is...
