Results 21 to 32 of 32
09-04-2006 #21
Alcino
It took a while but I might have a spindle for you. I find I'm building 2 Lotus 7s. The first is a rebody of a V8 MII using generaly everything from the MII including the front crossmember and A arms. The second is a bit OTT the front suspension starts with MII but the A arms are 3" longer on the lower and an appropriate amount on the top. The spindle is from a 91 Tbird which is 1" taller .5 shorter from the lower balljoint to WMS and by the time I'm done the KPI will be smaller. The spindle can be modded to use the 99 to 04 Mustang GT PBR calipers which will result in lower unsprung weight. It can be easily converted to 5 on 4.5 by using 94 to 04 Mustang hubs which bolt on.
