      Salem N.H.
      Big Block 69 camaro header clearance ?
      Anybody have a solution to my drivers side header being right up against thesteering box. Looks like a small dent would work yet a large one would be needed to get the power steering hose back in.
      Has anybody used a 90 degree angle fitting for the line?
      How about a different gearbox?
      The mounts are all new big block mounts, trannys bolted in????
      The engine appears to be where its supposed to BE !
      Hooker headers, bought used ( comps? )
      TIA Kevin
      69 Camaro 454
      HD soft Tail
      72 Telecaster
      Salem N.H.
      Thread Location
      Moderater
      Could you please move this thread to the correct locatinif possible?
      Thank You
      69 Camaro 454
      HD soft Tail
      72 Telecaster
      Aug 2011
      Camaro header clearance
      Quote Originally Posted by Whistle Pig View Post
      TIA Kevin
      Hi Whistle,
      I was curious if you ever found a solution to your problem of your header hitting against the steering box. I've had this issue for many years and have never found a good solution? Any specific kind of header you end up using? Any help is greatly appreciated. Thank you.
      Ramona, Ca. San Diego area
      doesnt look like he has loged on in over 4 yrs.
      I have a friend that has the same problem. He just ordered a set of Lemon headers.
      Maybe he will post up once he gets them installed.
      67 Camaro convertible (Jinx)
