      uvalde texas
      backspacing on tt2's 69 camaro question
      mini tubbing my 69 camaro. going to use torque thrust 2's. 2 inch drop, tubular front control arms. any help with backspacing is appreciated. wanting to do a 17x9 (275-40-r17) up front, 17x11 (315-35-17 drag radials) out back. is it do-able? what backspacings will work. need to order wheels soon and hoping to hear from someone with a similar setup that can share some info. thanks guys.....
      i dont know whats going to work for you but heres what i had, 69
      275/40/17 5.5bs 245/40/17 5bs
      69 camaro, 383 stroker, 700r, 3:73 auburn, JL stereo, marquez lights front/back, adj qa1's, custom dash, sts swaybars 1 1/4-7/8, global west a-arms/subframe connectors, suede interior.
      http://hobbystage.net/camaro/jigga99/
      Oct 2003
      Arvada, Co
      The front you will need 5.25BS on a 9.5 rim. Check CarlC's site as he has put 275 on front of his Camaro. You will lose some steering radius because your tire will hit the frame before full lock. The rear I am not sure of.
      Brian
