Results 21 to 27 of 27
Thread: My Junk Chevy Truck
10-12-2004 #21
- Sep 2004
- 167
dont know what to tell you guys..most guys that rebuild these trans will tell ya to drive around town with it locked out...My trans guy is a very sharp old grumpy dude and tells it like it is..now some Tech at the dealer has to keep his mouth shut or fear getting fired..if he tells you the truth the first thing you will do is go to the manager and then on up the ladder..if you read about this issue you will find that climbing in and out of O/D is not a good thing....a three speed is plenty till you get on the freeway??? most arterials are 45mph tops... our traffic in the Seattle area is about as bad as any LA traffic...its hard on all componets.... now pass me a beer.
Bud.
10-13-2004 #22Did you check the harness inside the door jamb?? I dont know how old you truck is, but it is common for the wires to break in the door jamb because they are constantly flexing. Open the door wide as it will go and then pop the rubber boot loose that protects the wires in the door jamb... inspect the wires for broken insulation and completely broken wires. just an idea...
Originally Posted by TurboLark
-Joe Cilluffo-
http://www.joesclassiccarradio.com
10-21-2004 #23
- Aug 2004
- 33
The 4l60e is the transmission put in most all 1500's, blazers, s-10's...when you get into the 2500 and 3500's you upgrade to the 4l80e which is pretty much bullet proof. So what's wrong with the 4l60e. Several things. Its a direct decendent of the 700r4, has an aluminum direct drum and an aluminum valve body. They also changed from a direct lock up converter to a pulsed lock up converter in the 4l60e's. THis is where the problems all stem from. The valve that pulses the converter to make it slip until a certian speed is reached can wear out its hole in that aluminum vlave body. Extra heat is also gernerated by this pulseing lock up converter. The fix is easy, but you have to be able to get the Transgo Shift Kit (the one in the orange box only sold to trans shops). It will convert the valve so that when it engages the lock up it engages the lock up, no slipping. Also if the vlave hole is worn they tranny shop will need to drill out the hole and insert a steel sleeve.
Once this valve wears out and you start experienceing slippage, it won't be to long before your trans will slip into a limp mode where it won't even shift out of second. Once it gets to this point you had better stop driving it or you going to puke the transmission fluid out onto the road and require a complete rebuild.
I put the trans go kit in my blazer and didn't have a lick of trouble. The dealer will deny that there is a problemwith the pulseing lock up, but if you look hard enough and deep enough in tech service bulittens you should find tsb's dealling with the slippage and its relation to the lock up converter.
10-22-2004 #24
