Results 1 to 17 of 17
03-21-2006 #1
- Feb 2005
- 320
Sorry guys but I have another welding question
Sorry guys for all the welding questions but jopefully this will be the last one. I will be welding very soon 1/8 to 1/8 304 grade stainless steel together with my mig. Now I know normally you would use ER308 for this but the problem is that there will be a piece of mild steel approx .040 thick in between the two. Should I set the welder to the 1/8 inch setting for stainless steel using ER 308 and weld right through the mild steel piece? or should I be using ER 309 with a tri mix and weld right through the mild steel? Will this contaminate the weld? Thanks Chris
