Results 1 to 11 of 11
Thread: help me stiffen my suspension
03-19-2006 #1
New to Pro-Touring
- Mar 2006
- San Francisco, CA
- 8
Hey everyone, got a new guy here that needs some legit suspension advice. I got:
71 el camino, 350, all iron, no a/c, suspension all stock except for moog front springs, stock height, moog rear cargo coils, kyb gasadjust shocks, 265/60r15, 4"+ ground clearance
Problem: suspension is way too bouncy. On typical pitted, garbage SF roads, bumps make it oscillate from front to rear (or vice versa) and it usually takes 3 back and forths to level out, unless I hit another bump. :bsjerk: Minor bumps seem to make the suspension travel its max travel sometimes, and trying to drive on the freeway and hit any high speed can be dangerous.
I love straight line performance, but this car is a daily driver that bends alot of corners as well, and alot of the roads I encounter are in poor condition. My budget is also extremelely limited. Ive pretty much concluded I will get a new sway bar with poly bushings, but I don't think that will solve the problem alone. And since el-cos parts are cross-linked with chevelle parts, that means I have alot of choices which can get overwhelming. What do you guys recommend?
