    Results 101 to 120 of 141
      Walton, NY
      Redneck-touring 383/6spd Z28
      This car is pretty much my first attempt at everything. Bought it when I was 18 and still haven't stopped dumping money into it. All built by me in my dad's garage (with the exception of the ring & pinion install). Now the build will continue in my own garage since I just bought a house.
      UPDATE 2013: no more 355. Forged 383 roller with Holley EFI is going in. Paint job next.
      There will be way too many pictures in this thread, cause I'm a pic whore.
      Engine: 355c.i. V8
      Transmission: T56 6-spd manual
      Horsepower: ~400
      Torque: ~425
      Exterior: Maroon
      Interior: Graphite/black
      Mods:
      .030 over
      forged TRW pistons
      10.55:1 compression
      Vortec 062 heads
      RPM AirGap aluminum intake
      Comp Cams Magnum 280H ([email protected], .480", 110)
      Hedman 1-5/8 long-tube headers
      Summit 3" X-pipe and U-bends I cut & welded for 3" mandrel dual-exhaust
      Flowtech 3" cut outs
      Summit 2.5" chambered mufflers
      750cfm Edelbrock Performer carb
      K&N X-Stream air cleaner
      MSD Ultimate HEI ignition w/ rev limiter
      Energy Suspension poly engine & trans mounts & CA bushings
      4.10 gears
      Moser axles & support cover
      SPEC stage 3+ clutch
      SPEC retrofit flywheel
      Pro5.0 billet short-throw shifter w/ shortened stick
      Denny's custom length 3" HD steel driveshaft
      Summit driveshaft loop
      Hitachi high-torque mini-starter
      Summit 100amp alternator
      MAD Electrical relays & Start'M'Up kit
      battery in trunk with NHRA-spec kill switch
      Proform electric water pump
      Volvo 60a fan & SPAL fan controller
      Hotchkis coil springs & sway bars
      KYB shocks
      NAPA heavy-duty balljoints
      Pro-Touring F-body solid body bushings & leaf springs
      Alston subframe connectors & PTFB g-braces
      IROC steering box
      95 Camaro leather seats & seat belts
      95 console, shift boot, shift knob and e-brake lever
      Equus gauges (speedo, tach, temp, oil pres, volts, fuel, air/fuel, boost/vac)
      custom-fabbed gauge bezel
      Summit shift light
      Manual 4-wheel disc brakes
      Hawk HPS pads at all corners
      1LE 12" front on B-body spindles with Wilwood GMIII calipers
      ZQ8 11.6" rotors with 2WD&4WD Blazer backing plates, calipers & ebrake
      Lokar e-brake cables to 4th-gen lever
      70 Corvette master cylinder for manual brakes
      MP brakes manual pushrod
      B&M line-lock
      Summit adjustable proportioning valve
      275/60R15 Mickey Thompson drag radials
      CE Slide-A-Link adjustable traction bars
      AN-6 fuel system
      pin-on fiberglass hood with 3" cowl
      flat-blacked everything
      18x8.5 & 18x9.5 wheels
      http://www.waltoncruisers.com/members/ericwood.html
      http://www.motortopia.com/vehicles/v...rs/v/182/i/z28
      Fired up the 355 today and it came to life like it was nothin. I guess I put everything back together right. There's one more thing to check off the list.
      I went from ****ty 336 heads to 062 Vortecs and a new Performer RPM AirGap intake and added a new K&N filter and Moroso Super HEI ignition kit. I also got an electric fan, all new gauges and a line lock. It should take me from about 9:1 to 10.5:1 and 300hp to about 390hp and 425 ft-lbs of torque, according to a CHP buildup. And, I got rid of all that gay chrome.
      Going from standard heads to the Vortec style was more work than I realized, I didn't think about the little stuff like throttle brackets and plug wire looms, but it's all done now.
      The heater core went though, so I gotta replace that when I tear out the dash and put in the 78 one. I'm glad I didn't already replace it cause I'd be pissed to have to take it out again. So the next project is the dash swap and wiring up all the new gauges. Then comes the line lock and subframe connectors... are these cars ever actually done???
      SWEET:
      GAY:
