      Calling all Camaros w/ MANUAL steering!
      I was wondering how it was driving around with 17" or 18" wheels with manual steering. How is the steering response? decent or real slow?
      What about in a parking lot, is it hard to manuver? I am contemplating swapping to manual because it is a much cleaner install, not as many accessories to drive,no hoses an pump to leak. But most of the steering boxes I've seen have been 6 turns lock to lock? If you got manual steering and you like it, let me know what kind of steering box it is or where I can find one, Convince me to go with manual steering!
      By the way, I am running a 74 camaro, Any help or suggestions are welcome. THANKS!!!!!!!!!!
      Jul 2002
      Muskegon, MI
      My car just plain sucks with the original manual steering. It always sucked and still does. 15" or 18" didnt matter. Still sucks.
      :edit A brand new manual steering box will do a lot better especially one with a quicker gear ratio.
      Jul 2002
      Mesquite, TX
      Hi Super (what's your name?), welcome to the site.
      Wheel diameter is not such a big deal - the tire diameter would remain close to the same anyway.
      Wheel width is a bigger influence - the wider the tires, the harder the car is to steer at a dead stop.
      When you're moving it's not too bad regardless of width; I'm sure you've driven a power steering car with failed power assist.
      I imagine that if you couldn't find a manual box with a good lock-to-lock number, you could fill a good power box with fluid and cap it off so it didn't leak out (others may be able to chime in on this to tell you that's a good/bad idea).
      El Dorado Hills, CA
      I don't really have a problem with my manual steering on my Camaro. It has had manual since I bought it. Never changed to power. I agree with Derek though, tougher to turn wheel when stopped, but not that much tougher...
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      Manual Steering
      What would be a good replacement, or donor car to get a quicker ratio box from. Is a manual box from an 80's S-10 or a 70 Camaro a good choice? I have driven my Camaro with the belt off the pump with my power steering box, And I had a 1969 3/4 ton gmc long bed that 47 turns lock to lock!!!!!!!, not really but I think you know what I mean. Niether one was any good. If you have swapped to manual steering,please chime in. THANKS.
      Santa Barbara, Ca
      What's up guys. I used to have a stock manual box in my 68. I have to say that it was not a fun experience. When I assembled my car after it was purchased, I used the stock power steering setup that came with it. Every part leaked, so I switched to a manual box off a 68 that my friend had crashed. Even with skinny drag tires in front (at the time), parking was still a pain. When I converted my car to handle, I still had the manual box, and it was much worse. The ratio was slow, and with wide tires it was hard to steer, even at speed. I switched to a fast ratio power setup with all new parts, and I couldn't be happier.
      -Andy
