Results 1 to 17 of 17
Thread: Ackerman Angle Question
03-07-2006 #1
I'm setting up a totally custom rack system in my 66 Mustang. This system's based on a Sweet manual rack, and I'm using tubular tie rods in order to connect to the spindles. This is where my question comes in. I've found some great information regarding Ackerman, and how to eliminate it in the cars this kind of rack was designed for....stock cars. Thing is, it's all regarding a front steer spindle. I'm using the stock 66 spindle, which is a rear steer. This question may seem silly, but does reversing the direction the steering is coming from reverse how positive and negative Ackerman is determined? Meaning, on a front steer car, positive ackerman (the good kind from what I understand) is measured to the front of the car (the steering arms move forward, rather than rearward?). Switching to a rear steer, would this reverse it or would positive Ackerman still be forward. I need this information to determine the best mounting position for the rack, either centered on the steering arm of the spindle, or a bit to the front or rear.
Thanks!
03-07-2006 #2you may want to reconsider that rack. if it is designed for a front steer suspension, then it will turn the opposite direction in a rear steer suspension.
POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
03-07-2006 #3my experience with ackerman is all in race cars but there is no good or bad ackerman its only better or worse for what I've done, basicly ackerman is the difference (speed or distance) in the turning of the front wheels , if your racing oval tracks theres (and its guestionable) a need for this but I don't think you want any on a street car . All you need to do is get the steering arms and balljoints the same distance apart and inline with your rack , ok theres alittle more to it than that but thats about it good luck
NOW WHAT???
lol
03-07-2006 #4I think you would have the opposite reaction to ackerman in the rear of the spindle than if it were mounted up front. I was just reading in my book though, the closer to axle centerline your rack is, the less effect the rack has on ackerman. So, if you are going to use this rack, I would put it as close to the axle centerline as possible.
JEffJEFF SHORTT
-IDEAL STEEL
03-07-2006 #5This is the rack I'm intending to use, my understanding is that you specify front or rear steer when ordering =).
Originally Posted by gen3bu
http://www.pitstopusa.com/detail.aspx?ID=3289
It's just that the setup page I was reading only talked about front steer cars, which is why I wasn't sure if the setup reversed on changing the steering position.
Anyhow, thanks for all your replies! Much appreciated.
03-08-2006 #6
- Aug 2004
- England
- 1,042
If you do not use ackerman the car will not steer all that happens is you turn the wheel and the car goes straight on ,I know as it did it on my street rod and that was just trying to get out the drive .
03-08-2006 #7I thought 'some' ackerman was necessary, but I'm far from a suspension expert. I've always 'modified' stock setups with better parts, this will be my first ground up build. Guess I'll go ahead and do a search online for 'Ackerman / rear steer and see what comes up =).
03-08-2006 #8You dont NEED Ackerman. Some cars have Parrallel Steer. This is basically, no to out/in on turns if I remember correctly.
Originally Posted by Is1BadFord
JEFF SHORTT
-IDEAL STEEL
03-08-2006 #9
