    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 58 of 58
      Jan 2003
      Arizona
      Quote Originally Posted by David Pozzi
      I've got a pair of 10 year old Stahl 1 3/4" headers but not installed. If you need a dimension off them relative to the head flange, I can extend off that and measure down to the collector for you.
      I'm going to bolt on a pair of headers that I borrowed. Maybe we'll compare some numbers. But I'm starting to grow weary of this search. Let's face it. Proper Pro-touring headers are $700 and up. We can pry it open (the wallet) or we can scrape, hammer, cut, weld, and/or leak.
      ________________
      Steve Chryssos
      Sep 2001
      Accord, NY
      I wish 1 3/4 tri-y's were made. Another option might be Doug's 1 3/4" regular design headers. I think Mean69 has a set of Hedman 1 3/4's he's happy with. They're not the 65003's though but one of the 'race' sets.
      68 camaro - SOLD
      Jan 2003
      Arizona
      Yup. Whomever builds 1-5/8" and 1-3/4 Tri-Y's that make power will corner the pro-touring header market. All twelve of us.
      Doug's was bought by Pertronix, who trimmed the line. I don't see any good 1-3/4's in their product line. Nothing confidence inspiring anyway.
      And Thorley was bought by Jardine. Same issue. Thorley had some cool part numbers. Looks like they got the axe too.
      ________________
      Steve Chryssos
      Newbury Park, CA
      The Lemons that are on a friend's car are superb. The basic design and layout is similar to the later model Stahl. Four years ago they were $850 with no coatings.
      After all of the effort, time, and heartache, next time I'm spending less money overall and getting either Stahl, Lemons, or a custom set made. My local exhaust guy does very good work and will make a set for around $1200 to my specifications and layout.
      I had a rant going, but better sense prevailed and I hit the delete button.
      Jan 2003
      Arizona
      I think this thread is ready for the exhaust section, if a mod or admin would like to move it over.
      ________________
      Steve Chryssos
      Nov 2004
      It appears that Stahl has at least three different major designs for the first gen camaro.....the Drag race set early, and late, and then the road race set. It appears that the routing is a lot different between the early and late. I like the idea of max ground clearance, but want the best fit up top too...I'm thinking at least for now, I go with the Stahl. I guess I should talk to them to decide which of their designs to go with.
      The late model ones seem like they're for raised exhaust ports? I think mine are only raised ever so slightly with the Track 1 heads....I wish Lemons had some good photos....
      Carl, what did you want to rant about? I for one want all the opinions I can get! We all know that 90% of the headers that supposedly fit our cars are crap. I want to know which of the GOOD ones, (stahl, lemons) fit the best and are what I want.
      ~~fred
      Nov 2004
      Carl,
      Any chance you can snap some pics of the Lemon's on your friends car?
      Jan 2003
      Arizona
      Quote Originally Posted by ItsA68
      Carl,
      What is it with header manufacturers and brand names? My car Stahled on my way to hire a Hooker. What a Lemon.
      Yeah well, I couldn't sleep. (No really, check the time stamp)
      ________________
      Steve Chryssos
      Northern Indiana
      I have a set of Super Comps 1 7/8" I'm thinking about replacing them pretty soon funding permitting. I've already had ground clearance issues with these, nice flat spots on the tubes, not real bad but pisses you off noe the less... I like the Stainless Works maybe next time. Might go with the 1 3/4" for a little more bottom end.
      "Champagne taste on a beer pocket book."
      Jan 2003
      Arizona
      Found this pic in another P-T.com thread. These are dougs headers part number 375Y. By far, this Tri-Y design is the ultimate full length header as far as ground clearance is concerned. But with 1-5/8" primaries, they are not appropriate for high power and or big port heads.
      ________________
      Steve Chryssos
      Nov 2004
      These are the 1 3/4" Hookers on my car. As you can see in the first shot, the primary passes right under the steering box where the pitman arm attaches. My car has heads with stock exhaust port location and there is evidence that the primary just barely touches the pitman arm when the engine torques over.
      Quote Originally Posted by streetfytr68
      Those are actually Thorley 376Y1. As far as primaries being to small I can point you to a few people running 1 1/2 primary headers on 383s running well into the 11s
      Newbury Park, CA
      Sorry, it's a ways away.
      The rant had nothing to do with real, factual, useful info. More of a venting session. I feel better now.
      Central CA USA
      Tracl 1's are raised a little, the fast burn heads are raised a lot.
      Nov 2004
      I had the 2131 1 3/4 Hooker super comps on my first Camaro, and the grease fitting on the passenger side tie rod hit one of the tubes. I think I just left it out unless I needed to grease the tie rod, and it was OK. Don't recall having problems with the pitman arm.
      Anyone have any pictures of the Stahl headers on their first gen small block car?
      ~~fred
      Jan 2003
      Arizona
      Problem Solved!!!
      ________________
      Steve Chryssos
      Sep 2001
      Accord, NY
      Unfortunately for me, the ports on those are too small for my heads. I agree the primary size for a street car is fine.
      68 camaro - SOLD
