      Apr 2002
      Turning Angle of Wheels
      I'm not sure if this is the correct term or not...I'm trying to determine a good baseline for the angle of the wheels (when viewed from above) when turned to full lock. I'm thinking 20-25 degrees is a good range. Comments?
      --JMarsa
      Central CA USA
      My 67 Camaro turns 25 deg from straight ahead, a turn radius of 20.4' to the inside tires.
      A shorter car would have to turn a deg or two less angle to turn the same circle.
