      Quick and Easy Question - Changing plugs on a ZZ4 Crate Motor (pic inside)
      Hi guys,
      Probably a really dumb and easy quesiton, but what is involved in changing the plugs on a ZZ4 355 Crate Motor? I have had my '68 RS Vert sitting for a while and it starts and idles perfectly, but is a bit rough under acceleration. I am thinking the tank of gas went bad since I forgot to put in the fuel stabilizer or the plugs are dirty and fouled.
      Should I just empty the tank and refill with new gas?
      Should I change the plugs?
      Something else?
      Here is a pic of the motor:
      http://www.danvene.com/gallery/68camaro/MVC_016F
      If I do change the plugs, do I need any special tools?
      Thanks for your help,
      Dan
      '68 Camaro RS Convertible
      Pics of my '68 Vert
      '02 Chevy Avalanche Z71
      Next Car: '06 Z06 if it has 500 HP
      Feb 2003
      Houston, TX
      Should be relatively easy, but since you have headers you might have to unbolt the headers to get access to some of the plugs. Just depends on if your headers allow for plugs to be removed or not.
      I'd replace the fuel filter first and see if that works. Bad gas can clog a fuel filter instantly and cause the engine to surge under open throttle.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Quote Originally Posted by Nine Ball
      Thanks Tony.
      Should I even bother replacing the plugs or is it most likely something else?
      When I put the car away it was running great. It sat for about a year, getting started about once every 2-3 months. Next time I took it out to actually drive it, it was very rough. Eventhough I let it run for a few hours and drove it a bit it hasn't gotten any better.
      I put a half a tank of new gas in and some fuel stabilizer, but it hasn't gotten better yet.
      Dan
      Pics of my '68 Vert
