      Converting a 700R4 from 4X4 to 2WD
      What exactly needs to change?
      Nov 2004
      San Antonio, Texas
      output shaft and tail housing
      That's what I thought. Is there a heavy duty output shaft available?
      Nov 2004
      Roanoke, VA
      Quote Originally Posted by amcmike
      The 2wd shaft will take a LOT of power before it breaks due to it being longer (absorbs shock loading better). Im doubtful you'll ever get the internals to survive any length of time at the power level it would take to break the 2wd shaft anyways.
      Can you break a 2wd shaft? Im sure its been done but Ive never had a broken one in my shop....broken 4wd shafts on the other hand are pretty common.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
