    Results 1 to 15 of 15
      Columbus, Ohio
      Hidden windshield wiper motor
      A long long time ago, someone posted a wiring schematic and installation notes on using (I believe) a ford escort wiper motor. It was installed behind the stock location, under the cowl. The existing hole in the firewall could then be patched. Anyone remember this or care to comment? Anyone? Bueller? Anyone?
      Darren
      Chicago
      we will be installing one in my project next week.
      Specialty Power Wiper is where we got our universal kit
      marty-mj
      Columbus, Ohio
      Thanks!
      Thanks for the heads up. I am on it. Any other comments are welcome
      England
      If your fitting it into a 67-69 camaro it was avw rabbit or jetta if your still interested will try and find the wiring i'm sure radio joe worked it out
      Columbus, Ohio
      Paul,
      That would be awesome. I awould appreciate the help
      Darren
      Does anyone have a website address for the specialty power wiper that gets hidden inside the cowl ? Thanks Chris
      England
      formatted the hard drive on the old comp and it was on there check search on the forum as its coming up on old posts,will still see if i have a drawing somewhere
      Feb 2004
      Paris, Illinois
      I've got them Paul...
      If you can't find it Paul, let me know. I still have them. Haven't had time to get my website back online after I moved back home to Illinois.
      Michael
      Michael
      1969 Camaro
      CamaroHeaven.org
      fQuick Garage: http://www.fquick.com/Overkill
      Phoenix AZ
      We also have done this, but we used a wiper motor out of an 88 Volvo.
      Pretty simple really, we had to cut off part of the original arm that mounts on the motor. We then re-welded it on top of the Volvo motor arm.
      Make sure whatever you use, that the arm on the motor has the same throw. Just measure from the center of the wiper motor bolt to the little ballie thing where the internal wiper arms mount.
      I think the orignal throw is 2", but dont quote me. Then we attached a simple L bracket to the unexsposed cowl. When you install the cowl you wont see the bolts or whatever you decide to use.
      The motor was mounted behind the internal arms, due to clearance issues, where as the stock one mounts in front of the arms.
      It took about two hours of fab and trial and error.
      wiring, we really dont care too much about all the different freakin options, we kept it simple and used two speeds, fast and faster. If this car sees the Power Tour we will just deal with it, but we have no plans to drive it in the rain.
      Ill try to post some pics soon.
      Chicago
      marty-mj
      mount joy pa
      zuess4u i would like to c your set up. sounds cool working on firewall cleanup next. mike
      Chicago
      The April Issue of Truck Builder has a complete how to install on a Pick Up. Great Pics and worth the read.
      marty-mj
      Columbus, Ohio
      Sweet, Thanks syborg, I will track that down.
      Darren
      Chicago
      it's a very easy set up and i think most people will find it much eaiser to do. The best part is you are remote mounting the wiper motor so you don't have to worry about all the mechanical linkages under the wiper cowl it's simply a cable.
      marty-mj
      Chicago
      Darren, shoot me an e-mail and i'll send you the scanned article.
      marty-mj
