- Aug 2004
- 345
pipe dope on threads in fuel system
i will be installing fuel lines in the next few days. i bought NPT to AN connectors. should i put sealant on the NPT threads, and if so what type.
10-04-2004 #2
- Aug 2004
- Vancouver BC
- 159
I wouls recommend againt using sealer. It can clog injectors. If the fittings are aluminum or brass (which they should be for fuel lines) the threads distort enough to seal without teflon. If you have to use sealer I would carefully use a little teflon tape. Be careful to not let any get inside the line though.
Originally Posted by kman67rsss
CoryM
10-04-2004 #3WHOA, WHOA, WHOA!!!!! NEGATIVE!!! NO TEFLON TAPE!! That's what clogs the fuel system. It's a Holley needle-and-seat nightmare !!! He is right,though, the compression should seal but if you want cheap insurance Lockitite makes a liquid teflon in a tiny white squeeze tube with red writing. It's at your local Pep Boys/Autozone/Checker..etc. One word of advice is the cure time is more than they advertise always (or do I use too much...hmmmm). At least 24 hours is what you'll want to wait before passing fuel through...good luck.
Originally Posted by CoryM
10-05-2004 #4
- Aug 2004
- Vancouver BC
- 159
When I say carefully I mean it. I would use a single pass, as far up the threads as possible. Globs of teflon thread sealer (the liquid) will clog stuff just as fast as tape. I have seen that many times. I find it easier to control the tape and make sure its not going to enter the system. With soft fittings I dont use any sealer...... ever. If it leaks, its not tight enough or its NFG.
10-04-2004 #5
