    Results 1 to 7 of 7
      Southern California / Maryland
      Fuel injector size ?
      Need to know what size fuel injectors I will need for a 496ci Stroked Mopar wedge.... will be between 600-650HP
      Apr 2003
      Central Valley, CA
      Naturally aspirated? Supercharged? Turbocharged?
      Reason I ask is the "typical" BSFC numbers vary for the different engine configurations.
      If you figure a "middle ground" .50 BSFC number for a naturally aspirated combo, I'd plan on ~50 lb/hr injectors.
      ( 650 hp X .50 lb/hp/hr (BSFC) ) / 8 (# of injectors) * 1.2 (20% headroom on the duty cycle) = 48.75 lb/hr per injector.
      If you're running turbo/supercharged, expect a higher BSFC. To play it safe use a .65 lb/hp/hr BSFC number in which case you'd be best off with 64 lb/hr injectors.
      Don't forget to match the injectors (high or low impedence) to your ECU.
      Troy
      1969 Chevelle
      Old setup: Procharged/intercooled/EFI 353 SBC, TKO, ATS/SPC/Global West suspension, C6 brakes & hydroboost.
      In progress: LS2, 3.0 Whipple, T56 Magnum, torque arm & watts link, Wilwood Aero6/4 brakes, Mk60 ABS, vaporworx, floater 9" rear, etc.
      mo
      i've have 160's in my 710.
      Oct 2005
      Granger,IN
      A good page for calculating injector size, Theres is a nice automatic caluculator there
      http://www.stealth316.com/2-air-fuel-flow.htm
      Stealth316.com has a lot of great technical article especially if you are going turbocharged
      Using the fuel injector sizing program 50lb/hr injectors @80% injector duty cycle and 50% BSFC are good for about 640 HP, Blown353 made a good suggestion
      Free hostings of solid models!
      http://www.wrenchmonkey.com/Webpages/Solids/Solids.html
      92 Stealth Twin Turbo with 3.5L Engine swap
      Looking for my next project, maybe an AWD 71 Lemans????
      nice... thanks guys... My plan is to for a while, run a 8:1 compression and hopfully get 650HP from it... The engine is not built yet but I am just doing the headwork right now... I want in the end around 800HP with a Procharger system... but I can always upgrade injectors later on - I want to get all the computer non-sense done ahead of time.... So I'll start looking for 50lb injectors --- dumb question but do any factory applications use these ?
      I dont think so. Most stock engines run 30lb injectors or smaller
      Cumming, GA
      I can give you a smoking deal on some low-impedance 65-pound injectors if you call me.
      Low-impedance injectors capable of supporting 900 horsepower. I ordered more than I needed, and now I have 7 extra sets to either sell or return. I'd rather sell them to be honest with you.
      These injectors MSRP for about $630 a set. Give me a call. You won't believe the deal.
      These are only recommended for after market type ignition systems with the appropriate drivers for low impedance injectors.
      Pink Top (part number 30-6508)
      http://www.powerandperformancenews.c...00_600x600.jpg
      Todd B.
      Vengeance Racing
      Formerly at:
      Kurt Urban Performance and Wheel to Wheel Powertrain
